 SC belt length with 2.7`` pulley
georgeman
georgeman
SC belt length with 2.7`` pulley Empty
PostSubject: SC belt length with 2.7`` pulley   SC belt length with 2.7`` pulley EmptyFri Mar 26, 2010 11:42 am
Good day!
Just installed 2.7 SC pulley instead of 2.85 stock.
I hear whistling sound because of slack belt. I don`t know know original length exactly, probably 1463mm. It`s difficult to take it off and measure. Anybody knows what lenght should I use with 2.7 SC pulley?
PostSubject: Re: SC belt length with 2.7`` pulley   SC belt length with 2.7`` pulley EmptyFri Mar 26, 2010 1:41 pm
.15" is not a much of a difference in size. the tensionser should take up the slack unless it is at the max position.
what most of us do with the S2 motor is just upgrade the tensioner pulley size from 3" to 3.5". and that is for a .4"+ pulley drop.
I have to ask since you dont have it in your sig, but what are your supporting mods with the 2.7?
Also, if you do actually have slack in the belt to the point that is it slipping at WOT then you may need a new tensioner, not a smaller belt or larger idler.
SC belt length with 2.7`` pulley Dsc_0110
Merit : 122
PostSubject: Re: SC belt length with 2.7`` pulley   SC belt length with 2.7`` pulley EmptyFri Mar 26, 2010 4:13 pm
If this is on the series one, (which the stock is 2.85), then your stock belt is fine(if its new). I run stock belt size and tensioner on a 2.5"
Also FYI, the series one is a breeze to change to a new belt. None of that removing engine mounts like the series 2.
georgeman
georgeman
PostSubject: Re: SC belt length with 2.7`` pulley   SC belt length with 2.7`` pulley EmptySat Mar 27, 2010 6:37 am
it`s all right at WOT. I hear whistling sound when idling. May be tensioner isn`t very good.
95 SC Riviera, AL-104 plugs and 95 octane gas for today. 180 t-stat, FWI and catalytic converter cut soon.
Before installing 2.7 pulley I measured KR by Tech 1, it displaed "YES" and figures up to "14" on WOT. But I don`t remember, are theese figures KR level or timing adjustment. Also I had "Weak 2nd cylinder" error at that time. Fixed now and I hope KR reduced too.
» Easy Belt Length Calculation: Pulley Swap Only
» So, You Wanna Ditch Vari-Drive?
» Chain in place of belt.
» lawnmower drive pulley question
» How to swap engine pulley on a briggs?
