Name : BMD Location : Canada Joined : 2009-04-28Post Count : 1161 Merit : 36
Subject: Scratched Glass Thu Apr 22, 2010 3:19 pm
Hey guys, anyone have a way for removing, or at least minimizing scratches in glass. I looked online and there are a few home made solutions. I also read that "jewelers rouge" used my jewelers to polish diamonds might work with a buffer. I got a small scratch on the driver side window, its deep enough for your fingernail to get caught in it but it isn't glaring, I see it everytime cause I know where it is. Its not large enough to have the glass replaced, but I thought I wouldn't hurt to see what you guys think first.
97 park ave Addict
Name : Tyler Age : 33 Location : MN Joined : 2009-03-06Post Count : 669 Merit : 21
isnt there a company called safelite that has some windshield filler machine? i remember seeing it on TV but im not sure if that was for a crack or a scratch, and off the top of my head i dont know of any glass polish. any pics of the scratch so we know what were dealing with?
BMD Aficionado
Scratch is about have an inch long, don't have pic of it. I don't think the stuff for windshields will work cause I think a windsheild is actually made of two planes of glass with an air gap in between, so the repair fluid fills this gap (might be wrong), but thanks for the response Tyler.
97 park ave Addict
in all honesty, youre probably right. i have no idea how a windshield is made but im guessing that company repaired cracks not scratches. either way im not sure ive ever seen a glass polish (not like i have ever looked though so im sure its out there) heres a few links of products i found so far, ill look more later but i wasnt able to find anything local:
Actually, a windshield (unlike the rest of the glass on the car,) is made of 2 layers of glass laminated with a layer of sticky plastic in the middle...
While the kind of damage those companies usually repair IS probably cracks all the way down to the plastic layer, which would give the repair material a better 'anchor', they do end up polishing it up on the outside so that it's flat and invisible. It would certainly be worth a phone call to ask if they can fill a simple scratch.
Name : Rick Location : Lancaster, MA Joined : 2008-09-13Post Count : 6282 Merit : 119
[quote="97 park ave"]in all honesty, youre probably right. i have no idea how a windshield is made but im guessing that company repaired cracks not scratches. either way im not sure ive ever seen a glass polish (not like i have ever looked though so im sure its out there) heres a few links of products i found so far, ill look more later but i wasnt able to find anything local:
http://www.autogeek.net/diglkitforma.html
Have you ever used the product listed above by any chance,?
I like the sound of being able to buff out my windshield along with doing the body, now that the Spring weather is here. I don't have any real scratches that I am aware of, but I have a stained windshield and small pock marks that you couldn't measure without a very accurate depth gauge with a pointed tip and be able to measure in 0.0001" They don't sound like much but when your traveling withe sun on your face it is very distracting. Between the inherent window glare and the condition of my w/s I'm almost ready for a new one. But i would like to find a product that could be idiot proof, so as to allow someone I know and trust. to do it after detailing the rest of the car. Maybe Ill do it and see what happens to my back.
BMD Aficionado
Thanks for the links guys. I've seen the Quixx product but it only works on acrylic glass or plexi-glass. I went to a local glass guy and he said if you can feel it then its easier to replace it. I haven't gone yet to large chain shop, so we'll see what they say. It looks like removing scratches from glass is pretty involved, based on this clip...
but I'll still go see what they say anyway, thanks for the responses!
That's one way to fix, but I think there is another way, using a filler compound.
Safelite can fix a crack all the way through, as long it's smaller than the size of a dollar bill. They use a transparent filler with a special machine, but it's not that expensive, and it's fast. I imagine they could do the same to heal chips and scratches. It's worth a call to find out, imo.
Here's a video of the process. The part at 1:30 looks like it would work with any scratch:
Thats true Dale, I'll have to check that out! Aaron, I know cracks can be filled that way, but mine is a scratch , like someone taking a sharp rock and draging it on the glass. I was hoping to find a DIY system for removing scratches, but from what I'm finding, the pros invest alot on the equipment required to take scratches out. So, I guess I need to keep checking shops until I find one with the system I need. Here another way to do it...
I wonder if there's a lot of difference? Most cracks I've seen are accompanied by a stone chip, which is really just a big scratch. If that filler compound can fill one of those, why not a deep scratch?
97 park ave Addict
Subject: Re: Scratched Glass Sat Apr 24, 2010 2:29 pm
i havent used any glass polish before, but this thread has definitely made me want to look into it a bit more. my glass is spotless but im sure a little polish can only help right?
i would imagine this is true, i would at least call safelite and see what they say im sure they would have something for scratches if they can repair cracks.
