 Abaddon's Riv
Go to page : Previous  1 ... 5, 6, 7 ... 15 ... 25  Next
Abaddon's Riv - Page 6 Empty
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyWed Nov 24, 2010 11:28 pm
LOL flyin.....
As for the noise, I forgot something.....please don't confuse the whine I'm referring to with the "hiss" that the pump and rack make when you hold the steering wheel to the lock. That noise is the fluid rushing back through the flow control pressure relief valve when it opens.
Merit : 153
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Nov 25, 2010 8:07 am
LOL flyin.....
there's also that PS hose TSB
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptySat Dec 04, 2010 8:56 pm
So, I actually got some quality time to work on polishing the GenV yesterday. I was dead at work, and only had to work on one car. So, I spent the whole day destroying my fingers, arms, wrists, shoulders and elbows.
This is what I started with in the morning...
Abaddon's Riv - Page 6 100921_131809
I got it all blended to this. Notice the rough scratches still there...
Abaddon's Riv - Page 6 101203_120853
This is before trying the polish, all rough marks removed (from this side)
Abaddon's Riv - Page 6 101203_155204
I polished 2 of the grooves and part of the case.....
Abaddon's Riv - Page 6 101203_160509
This thing is starting to look amazing. What you see sitting there is just the case. I took the whole thing apart.....gonna polish it inside and out, without touching where the rotors go. If I have time next week, I should be able to get it all done, including the LIM Abaddon's Riv - Page 6 Icon_smi
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptySat Dec 04, 2010 10:27 pm
WOW, Scott that looks amazing man, great job. How long did it take for the transition in your pics to take place, and how long will it stay looking like that once its in use?
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptySat Dec 04, 2010 10:40 pm
Thanks BMD! I worked on it for about 4 or 5 hours. It's definitely a PITA, but watching the ugly duckling turn into a swan before your eyes makes you wanna keep going. Getting to that final shine is like yay yay
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptySat Dec 04, 2010 11:38 pm
that shore is purty!
Merit : 135
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyWed Dec 08, 2010 12:52 pm
That case is looking tasty scott! You definitely have a lot more patience than me, or a better technique. What all tools have you been using?
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyWed Dec 08, 2010 7:51 pm
tongue Trust me, it's a GIANT PITA and I don't recommend doing it....
I first used an Aluminum bur to blend the corners/edges (first pic). Then I used a grinding stone (the proper size) down the centers of the top. After that, it was a mix of 36, 40, 50, 120, and 240 grit Roloc discs and sandpaper. I also bought a box of Super-Fine red Scotch-Brite discs for the "final" touch. However, the "Super-fine" looks great until you try to polish it. EVERY SINGLE little spot that's missed shows up. So, change of plans.... Abaddon's Riv - Page 6 Icon_hea
I ended up buying a $8 20 piece set of 1/4" shank diamond carbide burs (Harbor Freight) to get into all the really hard spots. For the final smoothing before polish, I'm now using purple Scotch Brite pads. They work great. I was able to use the brown rouge with the red (rough) ball on my polisher to smooth out the fine scratches (after Scotch Brite), then the white rouge with the cotton ball (large) for final polish.
Right now the entire case is a "flat" smooth. I have more pics, just haven't uploaded them yet. It's definitely a grueling process, but, it's satisfying.
I'll take a pic later with everything on my workbench that I've used lol.
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 09, 2010 10:32 am
Updated pics!
Whole thing ground down
Abaddon's Riv - Page 6 101207_084633
In this pic, the small spaces aren't smoothed yet, but I've since got them done with the little diamond carbide bits I bought
Abaddon's Riv - Page 6 101207_124716
This is the finish that the purple Scotch Brite leaves. You can also see the spaces done with the carbide bits (bottom of pic). Still need to smooth them by hand. Notice the casting mark (round thing) that I removed and smoothed. I did it where the throttle body mounts also. I think I'm going to do the same thing on the other end....
Abaddon's Riv - Page 6 101207_175747
More pics to come!!!!
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 09, 2010 10:38 am
Very nice.
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 09, 2010 3:25 pm
wow! lots of work! i guess it means that youre not planning to paint it?
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 09, 2010 4:15 pm
Nope, no paint. Probably just a clear powder coating to seal it up once I'm done.
Merit : 135
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 09, 2010 5:57 pm
That's bad-ass! You eliminated two of the casting lumps too!
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 09, 2010 6:36 pm
I like it much better than paint.
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 09, 2010 6:48 pm
Keep goin' man!
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 09, 2010 7:02 pm
Yep! I'm thinkin I'm removing that 3rd one too. It looks funny all by itself Abaddon's Riv - Page 6 Icon_con
Thanks for the love guys! Hopefully in a month or so I'll be able to get it finished.
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 23, 2010 11:23 am
UPDATE!!!!!
I made a short video instead of pics. The finish on it now is with Purple Scotch Brite. Polish is right around the corner! Can't wait for that PITA.....the video is a bit grainy/choppy cause I did it with my cell phone. Somehow during the upload it slows down scratch
Merit : 122
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 23, 2010 1:00 pm
sweet.
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 23, 2010 4:07 pm
Looks serious, great result Scott!
crlombardi69
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 23, 2010 4:28 pm
You must have to much spare time! I think I will just scuff and shoot it with hi-temp enamel. It looks awesome though.
http://crlombardi69@yahoo.com
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyThu Dec 23, 2010 4:38 pm
HAHA. Speaking of, when the hell you gettin all your chit together for that bucket of bolts? razz
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyMon Dec 27, 2010 4:09 pm
Another update. It's almost done. Still have most of the backside of it to do, and need to touch up all the lil corners, but here she is....
Abaddon's Riv - Page 6 101227_155956
Abaddon's Riv - Page 6 101227_160012
Notice the "haze" on the right of the lower photo. I still need to buff that side out. Other than that, she's almost done! I have to get my MPS (not purchased yet) mounted on the nose before I polish it. Don't want to f-it-up after the polish. When it's all said and done....ON TO THE INTAKE!!!
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyMon Dec 27, 2010 5:52 pm
WOW!!!!!
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyMon Dec 27, 2010 10:47 pm
This is getting exciting Scott. Just curious, are you using a phone camera?, because the pics are not doing your work justice. shocked
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 6 EmptyMon Dec 27, 2010 10:57 pm
You DO realize what this means, don't you... There is now a moral imperative to find chromed rocker covers, chromed exhaust headers, chromed alternator and chromed injector plumbing! clap
(Hmmm... Does anyone chrome heads and blocks??)
Abaddon's Riv
Page 6 of 25Go to page : Previous  1 ... 5, 6, 7 ... 15 ... 25  Next
