 Abaddon's Riv
Go to page : Previous  1 ... 8 ... 12, 13, 14 ... 19 ... 25  Next
Abaddon's Riv - Page 13 Empty
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyFri Nov 01, 2013 12:32 pm
Dang......
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyFri Nov 01, 2013 1:51 pm
At least it's Friday? You work Saturdays.. dont you?
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyFri Nov 01, 2013 2:03 pm
Yep
AND, looking under my car whilst putting my wheel back on, I noticed that my oil level sensor is cracked and leaking. The O-ring is broken and sticking out the side.....
giveup <----------on today
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyFri Nov 01, 2013 5:48 pm
whod you piss off?
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyFri Dec 20, 2013 3:50 pm
Intercooler is in my possession. I opened it up last night. It's B-E-A-Utiful  cry
I didn't realize how freakin long the Water-to-Air exchanger is. The water pump is pretty big as well...
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyFri Dec 20, 2013 5:01 pm
Pics please?
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyFri Dec 20, 2013 5:51 pm
Pics, bro. Taunt us.
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptySat Dec 21, 2013 1:41 pm
Are you going to pull off the aluminum bumper and cut it out to fit in the exchanger?
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptySat Dec 21, 2013 5:02 pm
I . have . no . clue. Lol. All I know is that the entire upper half of the engine is coming off, and so is the front end.
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyMon Dec 23, 2013 11:44 am
Abaddon's Riv - Page 13 20131211
Here it is in all its glory. That's a 12" subwoofer behind it....
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyTue Dec 24, 2013 5:29 pm
bump for pic....
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyTue Dec 24, 2013 5:35 pm
That exchanger is huge. Is there enough room for it to fit?
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyTue Dec 24, 2013 6:02 pm
My jealousy levels are off the charts.
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyTue Dec 24, 2013 6:10 pm
weeeeeeeeeeeeeeeee................
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyTue Dec 24, 2013 6:14 pm
Are you putting a cam in too? Your Riv is about to be crazy. He's coming for you Codith...
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyThu Dec 26, 2013 8:49 am
Well, I'm going to have to make room for it I suppose.
@SirPsycho....let's not get ahead of ourselves. Codith has WAYYY more done than I do.
Merit : 130
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyThu Dec 26, 2013 7:04 pm
Yayyyy! Gonna be an exciting year!  What are the dimensions of the heat exchanger?
I just went on zzp and it looks like they only have really one now. That stage 3 is quite different in size from the stage 2 they had which was pretty much like my frozenboost 101. I'm interested to see how that goes. You might actually be able to use those two horizontal brackets to attach to the bumper support though. The top half or so of my heat exchanger gets almost no air flow through it from how it looks but maybe you'll get better utilization out of yours being that it's flatter and wider.
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyTue Dec 31, 2013 5:41 pm
It's 33" long, 7" high, 3" thick core, and 5" thick on the ends. If I have to, I'll fab up some brackets to hold it. I'm thinking down where the opening is for the radiator. I don't have a problem cutting some of that out if I have to.
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyFri Mar 21, 2014 9:39 am
Ordered new S/C snout bearings, Viton seal, and Aluminum Coolant Elbows today. Planning on getting the Valve Springs, Valve seals, VC gaskets, and the Karma blower installed next Saturday...also rebuilding my existing snout (obviously). If I can find a machine shop to open my TB adapter to 75mm all the way through, it should be completed on that Saturday. If not, probably wont be done until later in the week.
The Intercooler is going to wait a little bit......it should be done this summer, just not right away.
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyMon Mar 24, 2014 10:48 am
Yay. Snout bearings, seal, and Aluminum coolant elbows are here. I have to say...for $10, EVERYONE should buy these coolant elbows if they ever have to remove the LIM. These things are beefy.
Project Karma blower starts Thursday night. I'm going to stay late and get the upper half of the engine torn off. Still looking for a machine shop to port the TB adapter for me.....
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyMon Mar 24, 2014 10:59 am
You going to port the LIM, or at least open it up to match Karma's blower?
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyMon Mar 24, 2014 11:16 am
No. As far as I know, the LIM doesn't have to be opened up at all. The opening is bigger than the S/C outlet. I will change the LIM when I install the Intercooler.
Merit : 122
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyMon Mar 24, 2014 3:03 pm
It'll be ok to leave the LIM inlet stock.  There will be a bit of turbulence since the blower was done to take full advantage of an IC, but other than a little heat from that there will be no problem.  The differences in heat output on this blower over stock will more than offset it, and you will be even better off once you go IC and do the needed LIM inlet opening for that.
Take pics!
Edit: for the coolant elbow, you removing the bracket to put it in? or taking off the LIM? Cause if the LIM is coming off... just sayn.. it could get ported...
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyMon Mar 24, 2014 3:12 pm
Not taking the LIM off at this point. I have to move the tensioner assembly back to get the rear valve cover off. No sense in buying 2 sets of LIM gaskets. I plan on buying a full ported, machined for an IC LIM very, very soon.
I'm going to pull the front fascia off and start fabricating parts and figure out where I'm going to mount the heat exchanger before I go ahead and bolt up the IC and piping. That'll buy me some time on the LIM.
Name : Going Nowhere Fast
PostSubject: Re: Abaddon's Riv   Abaddon's Riv - Page 13 EmptyMon Mar 24, 2014 9:34 pm
We should be intercooled by now don
Abaddon's Riv
Page 13 of 25Go to page : Previous  1 ... 8 ... 12, 13, 14 ... 19 ... 25  Next
