 Abaddon's Riv
Go to page : Previous  1 ... 8 ... 13, 14, 15 ... 19 ... 25  Next
PostSubject: Re: Abaddon's Riv   Mon Mar 24, 2014 10:03 pm
Johnny5 wrote:
We should be intercooled by now don
Who's Don?
Dude, Scott. Cannot wait to see the beast you are making!!!
Name : Going Nowhere Fast
PostSubject: Re: Abaddon's Riv   Mon Mar 24, 2014 11:08 pm
He is A Bad Don BKA Scott
Merit : 179
PostSubject: Re: Abaddon's Riv   Fri Mar 28, 2014 8:29 am
Well, I got a HUGE jump on car last night. I had about 1-1/2 hours "free" time. I got the S/C off, and modified my LIM...I plugged the coolant ports that go up through the S/C and TB to keep the coolant out of it. I also removed the coolant bypass under the EGR tube and used an Aluminum Bur to knock down the "wall" to allow more coolant to flow to the rear head. I got the LIM all cleaned up and ready for install.
Unfortunately, I have zero work today. I came in to an empty slot of Repair Orders. On the flip side, I can work on my Riv all day  happy
I plan on getting the snout rebuilt, and the Valve Springs/Seals installed. The only thing I have left to remove to get to that stuff is the rear heater pipe, and the coil pack bracket.
I have pics in my phone, and I'll upload them when I'm done and can actually sit down.
Cross your fingers, and wish that I don't drop a valve into a cylinder!
PostSubject: Re: Abaddon's Riv   Fri Mar 28, 2014 9:18 am
Pictures, AAAALLLL THE PICTURES.
Merit : 179
PostSubject: Re: Abaddon's Riv   Fri Mar 28, 2014 10:49 am
Dammit!!! Our heated parts washer is down!!!
Merit : 179
PostSubject: Re: Abaddon's Riv   Fri Mar 28, 2014 6:43 pm
Got all of the Valve Springs/Seals installed. VC gaskets are replaced. Took the time to clean the Valve Covers while they were off. I installed everything back to where all I have to do is bolt the S/C back on once I get the snout rebuilt.....hopefully Monday?
PostSubject: Re: Abaddon's Riv   Fri Mar 28, 2014 8:27 pm
Pics or none of this happened!!! You know how it goes!
Merit : 128
PostSubject: Re: Abaddon's Riv   Sat Mar 29, 2014 1:20 pm
Gettin er dun! If you're really hurtin on finding a shop to open up your tb adapter, you can send it to me and I'll enlarge it to whatever you need. I already made a bed plate with the late style northstar bolt pattern for my 78mm project. Why isn't it 75mm already?  scratch
Merit : 179
PostSubject: Re: Abaddon's Riv   Sat Mar 29, 2014 1:35 pm
It IS 75mm. Actually, I'm pissed because it's 76.8mm, NOT 75mm. Karma opened the new blower up to exactly 75mm. Now I have a ridge between the adapter and the blower. I'm certainly not touching this blower....I have pics of it. I'll load them soon.
Right now I'm at the shop rebuilding my snout.
PostSubject: Re: Abaddon's Riv   Sat Mar 29, 2014 2:22 pm
dunno if i missed it but what MAF sensor will you be running, Scott?
Merit : 179
PostSubject: Re: Abaddon's Riv   Sat Mar 29, 2014 2:50 pm
I already have the N* setup. It's been installed for years now.
Merit : 122
PostSubject: Re: Abaddon's Riv   Sat Mar 29, 2014 11:17 pm
... Well you said to make it 75mm. smile
Merit : 179
PostSubject: Re: Abaddon's Riv   Sun Mar 30, 2014 5:06 pm
I know that. I'm certainly not pissed at you. I just went by what ZZP claims on their site. With the old blower, I just mounted the adapter and scribed a line to open up to. I never bothered to physically measure it.
I got the snout rebuilt yesterday, and got the blower assembled. I just need to transfer the BBV and PCV valve. I also installed my phenolic coupler that I forgot I had...yet another part in the collection lol.
I'm debating on whether or not to replace the pushrods and rockers. I have a few that are showing their mileage and abuse. For $40 I can replace all the rods. I'll have to check how much the factory rockers are. If they're too much, I think I'm going to swap them all with the Series III set I have laying around. I assume they're the same ones. Haven't checked yet.
I'll definitely get it back on the road by Friday. I can stay until 10pm or so at the shop Thursday night. That gives me a solid 3-4 hours of Riv time. I'll have to have the guys help me push it out of the shop tomorrow morning. It's in pieces in one of my stalls. I have Riv shit scattered everywhere lol.
Merit : 128
PostSubject: Re: Abaddon's Riv   Mon Mar 31, 2014 6:30 am
When I worked the inlet on my genV, I blended the machined 75mm lip out and ended up somewhere around 78mm without really trying to enlarge it. Really you could just do that and be good.  dunno It wouldn't be a very hard to do even if you are doing it by hand with a rotary abrasive or whatever and then just blend and smooth it nice and done. cover and tape off the inlet really good first so you don't have to tear down the blower.
I'm pretty sure my zzp throttle body adapter is pretty much dead nuts sized to the throttle body. That's weird yours a is bigger. I dunno - when I take my adapter off and bore it to the new tb i'll actually measure everything for real.
Merit : 122
PostSubject: Re: Abaddon's Riv   Mon Mar 31, 2014 8:34 am
I guessing he doesn't want to grind off the thermal barrier I put on the inlet. Could still get away with grinding the first half inch or so to smooth the transition. The coating was baked on, so it shouldn't chip if the leading edge was ground back a bit. (I don't *think*)  scratch
Merit : 179
PostSubject: Re: Abaddon's Riv   Mon Mar 31, 2014 9:06 am
Bingo. I certainly don't want to take off that barrier.
Maybe when the Intercooler project gets started I'll consider doing it.....
Merit : 179
PostSubject: Re: Abaddon's Riv   Mon Mar 31, 2014 9:36 am
Here is the ridge I'm talking about. You guys think I should knock it down or leave it for now?
PostSubject: Re: Abaddon's Riv   Mon Mar 31, 2014 9:39 am
I would leave it. Even though Karma thinks you'll be OK as far as not damaging the thermal coating, I wouldn't want to risk it.
Merit : 179
PostSubject: Re: Abaddon's Riv   Mon Mar 31, 2014 7:36 pm
This effin supercharger whistles lol....it's crazy. After all the oil and coolant burns off of everything, I'm going for a ride.
I (obviously) got it all together
Something doesn't sound right. I think the bearings in the rotor pack I bought are rusty. I have a hollow, rolling sound, and the brand new S/C fluid is brown. Wtf.....
PostSubject: Re: Abaddon's Riv   Mon Mar 31, 2014 9:47 pm
That doesn't sound good. Can you rebuild the bearings or do you need to buy a new rotor pack?
Merit : 179
PostSubject: Re: Abaddon's Riv   Mon Mar 31, 2014 10:45 pm
I'm sure everything in there is rebuildable with the right equipment, although I'm yet to see purchasable bearings for the rotor pack.
It seems to have quieted down...I drove her home tonight. We'll see how it sounds in the morning. I think I'm going to leave her at the shop for the week and try to get the P/S pump replaced. I also need to replace the belt tensioner. It felt horrible when I released it.
I just need some good time alone with her. Even though I'm a mechanic, the last thing I want to do is work on my own car when I get home. Things always get put on the back burner until absolutely necessary. She deserves to be right again...even if it means not driving it for a bit.
Merit : 122
PostSubject: Re: Abaddon's Riv   Tue Apr 01, 2014 8:30 am
You can do pack bearings but they are kind of a pain. There is a cast edge that you have to remove to be able to get them out, and then there is pressing the gears back on so the rotors still mesh right. Kinda a shim the rotor tips thing whilst slid into the casing to get it right. Its honestly less pain to buy another pack. Even if you might get the odd dud.
Merit : 179
PostSubject: Re: Abaddon's Riv   Tue Apr 01, 2014 10:07 am
Right. I really don't want to take it apart again sad
I think I have a header leak now, or the DP is coming apart. Sitting in the driveway through the winter was hell for this car. I'm seriously tempted to give up on it and start a new project. I'll gut this car of everything I've done and off it. After seeing underneath it yesterday, and what the winter has done, I don't think I have any other option. It's going to fall apart very soon. Damn shame too. It's only the underbody that's a disaster.
Here in Michigan, we can make a car run forever, but unfortunately we can't keep the bodies attached to the frame.....
 giveup
Merit : 122
PostSubject: Re: Abaddon's Riv   Tue Apr 01, 2014 11:17 am
At least the rotor pack is an easy swap. (Not at all like the m62)
Sucks about the under body. Drive it till the front leaves the back behind! Or at least drive the crap out of it for a summer.
Merit : 179
PostSubject: Re: Abaddon's Riv   Tue Apr 01, 2014 12:24 pm
Yep. I want to drive it. It's driving me nuts about the whole situation. I've had this car for a very long time, and I really don't like the idea of getting rid of it. However, I am a realist, and I see no sense in wasting more time and money in something that's inevitably going to fall apart. I think I'm going to replace the P/S pump (I have a brand new GM one in the basement), and get this crazy noise figured out. I'm hoping that it's just a header tick of some sort. It's only audible under a load, and gets CRAZY loud at WOT. The Knock sensors aren't picking up any knock, so I'm praying that it isn't the engine itself. The thing runs great, just noisy as hell.
I'll be actively looking for a new project over the summer months. If/when it happens, this Rivi is getting gutted of everything not factory that I've installed...including the transmission. That thing is definitely going in the next 3800 car.
Abaddon's Riv
Page 14 of 25Go to page : Previous  1 ... 8 ... 13, 14, 15 ... 19 ... 25  Next
