 Changing shift points
TheNewEra95
TheNewEra95
Changing shift points Empty
PostSubject: Changing shift points   Changing shift points EmptyTue Apr 27, 2010 11:47 am
Is it possible to up the shift points on our 95s?...Im kinda not content with my car shifting @ 5200rpm...feel like its not using all its potential... is it possible to flash your pcm, or get a chip to change this?.... evil
Merit : 122
PostSubject: Re: Changing shift points   Changing shift points EmptyTue Apr 27, 2010 11:52 am
Have a look at this thread:
http://rivperformance.editboard.com/series-i-scans-tuning-f14/code-scanning-setup-for-the-1995-riviera-t144.htm
Found on page 2 is this link:
http://www.3800pro.com/forum/general-tech/26439-tuning-obd1-3800s.html
Also you can get PCM from http://www.gmtuners.com/.
Its worth a note that the 95's powerband is lower RPM, which is why it shifts lower than the series 2. You would really need rockers to take advantage of a tweak in the shift points.
PostSubject: Re: Changing shift points   Changing shift points EmptyTue Apr 27, 2010 11:56 am
Agreed. Even Series II engines don't do much breathing above 5500 RPM unless you mod the intake, combustion, and exhaust stages for better flow.
» Brute Force Clutch Spring Question
» Changing wheel bearings
» Time between points rules - who cares?
» Murray shift on the go trans
» Honda Engine NO SPARK even at the points
