 rubber between quarter panel and Sail Panel
envus87
rubber between quarter panel and Sail Panel Empty
PostSubject: rubber between quarter panel and Sail Panel   rubber between quarter panel and Sail Panel EmptyFri May 07, 2010 3:59 am
Anyone know how to remove the thin rubber piece between the quarter panel and the c pillar? It's in a channel in the body and I'd rather remove it this time than try to fine line mask it off again....not sure if you have to get to it from the trunk or not.
PostSubject: Re: rubber between quarter panel and Sail Panel   rubber between quarter panel and Sail Panel EmptyFri May 07, 2010 4:00 pm
99Rivman wrote:
Quarter Panel Molding:
Remove by removing BLUE circled tip at back end from under Rear Window Molding, has 2 side tape holding it on the roof panel…RED square…then hooks over bolt sticking into trunk opening...circled in RED, then just pulls out from between roof and quarter panel. The front end should be under the Quarter Window Molding.
Roof Panel Filler…circled in RED…P/N…R/L…25638874-5
rubber between quarter panel and Sail Panel Paint_38
rubber between quarter panel and Sail Panel Paint_39
rubber between quarter panel and Sail Panel Paint_40
rubber between quarter panel and Sail Panel Paint_41
PostSubject: Re: rubber between quarter panel and Sail Panel   rubber between quarter panel and Sail Panel EmptyFri May 07, 2010 4:02 pm
I forgot to ad, the driver’s side I believe, is no longer available so be very careful removing them.
Merit : 102
PostSubject: Re: rubber between quarter panel and Sail Panel   rubber between quarter panel and Sail Panel EmptyFri May 07, 2010 7:35 pm
Just to clarify, I believe the blue circle referred to as the starting point is the one in the 2nd photo, not the first.
(It's been a while, but I think I just grabbed the nipple over the bolt and pulled, and the rear tip slid out...)
And NIck, for folks searching in the future, would you mind changing the thread-title to C-pillar or Sail Panel? Thanks
envus87
PostSubject: Re: rubber between quarter panel and Sail Panel   rubber between quarter panel and Sail Panel EmptyThu May 13, 2010 3:38 am
not a problem, I should have realized that when I was writing it.
Thank you both for all the info, this will save me plenty of frustration.
» I have to laugh at the TSN panel... Burke lovers
» New custom dash panel and switches
» Flexible Solar Panel Kit for Charging Minelab Metal Detectors
» NEW BACK LIT SWITCH PANEL
» Current Panel
