| Find on craigslist | |
SCbuick010 Member
Name : Bryan Joined : 2010-02-09 Post Count : 73 Merit : 1
| Subject: Find on craigslist Wed May 12, 2010 7:40 pm | |
| Im kinda looking for an engine to start my 3800 project with, because my rivi is getting up there in miles (162,xxx). I found a really cheap series 2 on craigslist. Do you think I should jump on this?
http://omaha.craigslist.org/pts/1737365894.html | |
| Subject: Re: Find on craigslist Wed May 12, 2010 7:48 pm | |
| the pic tells me its a rusty piece of junk. did the guy not have the presence of mind to at least cover the motor up? $200 ain't bad,but take a mechanic buddy,if your not comfortable grading a engine that's on the ground,to test it. who knows,it could be $200 worth of nothing... | |
| Subject: Re: Find on craigslist Wed May 12, 2010 7:51 pm | |
| I think you should do a cylinder balance and a leakdown test to reckon the quality of the engine you have -- because odds are you DON'T need a new engine. Reason is the Series I and later GM 3800 engines were engineered and fitted extremely well. That engine money would buy you a nice fat downpipe and some other stuff.
Now, if you are going to drive the Riv while building a replacement engine then do a swap, that's different and maybe you want an engine to build on. But if you are going to do mods 1 by 1 odds are the engine in your Riv will do - need to measure things to see what the condition and wear really are.
SCbuick010 Member
| Subject: Re: Find on craigslist Wed May 12, 2010 7:57 pm | |
| I want to drive my car while Im building an engine | |
| Subject: Re: Find on craigslist Wed May 12, 2010 8:08 pm | |
| go for it. it would be illogical to rebuild an engine without having the heads milled.$250 to $400. milling the block,if necessary,$600. boring the cylinders,$350. $1800 is what it costs around my way to have an engine rebuilt. new pistons.new rods. new everything. plus machine work. and that's a "good" price. give a local engine builder $50 bucks to go with you and have that engine checked out. i can buy a complete junked engine my way for $500 to $650...so....do the math...good luck though. | |
SCbuick010 Member
| Subject: Re: Find on craigslist Wed May 12, 2010 8:09 pm | |
| What about this for a project engine?
http://kansascity.craigslist.org/pts/1732074856.html | |
SCbuick010 Member
| Subject: Re: Find on craigslist Wed May 12, 2010 8:10 pm | |
| you can get a rebuilt engine for $500-$600 robotennis? | |
| Subject: Re: Find on craigslist Wed May 12, 2010 8:13 pm | |
| - SCbuick010 wrote:
- What about this for a project engine?
http://kansascity.craigslist.org/pts/1732074856.html that sounds like BS. there is no such thing as a "minor spun bearing" lol. if its spun,its toast. | |
SCbuick010 Member
| Subject: Re: Find on craigslist Wed May 12, 2010 8:34 pm | |
| I need to find something pretty cheap, I want to start a project hear soon | |
| Subject: Re: Find on craigslist Wed May 12, 2010 8:44 pm | |
| You should be able to find a low mile complete short block in the $500 range. An L67 or L26 completely stock lower end should take you into the 11s or last 200,000 miles (probably not both) without a rebuild. The perfomance parts you need are all airflow related - head porting, cam, valvetrain, intake and exhaust. But the bottom ends of these are pretty bulletproof.
I would start with a low mile L26 block if you can find one. Morad Parts company usually has a few. | |
| Subject: Re: Find on craigslist Wed May 12, 2010 8:45 pm | |
| - SCbuick010 wrote:
- Im kinda looking for an engine to start my 3800 project with, because my rivi is getting up there in miles (162,xxx). I found a really cheap series 2 on craigslist. Do you think I should jump on this?
http://omaha.craigslist.org/pts/1737365894.html That's probably not a bad starting point, but it's ummm... weathered looking, and unknown milage scares me a bit. But the price is right, so take your chances if you can afford it!!! | |
SCbuick010 Member
| Subject: Re: Find on craigslist Wed May 12, 2010 9:10 pm | |
| If I could get the one with the spun rod bearing for around $100-$125 would it be worth it? I would more than likely completely rebuild it anyway. I just want a starting point. | |
| Subject: Re: Find on craigslist Wed May 12, 2010 9:33 pm | |
| when you say ,rebuild, how will you rebuild it? and what do you think it will cost you when all is complete? | |
sburch23 Addict
| Subject: Re: Find on craigslist Wed May 12, 2010 9:39 pm | |
| What specific problem are you having? 162000 is just getting broken in. I have almost 250,000 without any serious problems. | |
SCbuick010 Member
| Subject: Re: Find on craigslist Thu May 13, 2010 3:05 am | |
| There isnt a problem, my car is running great. But In my opinion 164,000 miles is way too many miles to do any extensive mods to it. So I will just leave the engine in my car as is, and work and learn on a project engine, and when Im happy with it I can drop it in. | |
| Subject: Re: Find on craigslist Thu May 13, 2010 3:39 am | |
sburch23 Addict
| Subject: Re: Find on craigslist Thu May 13, 2010 9:25 pm | |
| That sounds like an interesting way to go about it. | |
| Subject: Re: Find on craigslist Fri May 14, 2010 12:11 am | |
| The seller infers that it has been garaged, but it doesn't look like it..???????? | |
| Subject: Re: Find on craigslist | |
