 95 Riv problem code P0257
Mike95
Mike95
Name : Mike manchester
95 Riv problem code P0257 Empty
PostSubject: 95 Riv problem code P0257   95 Riv problem code P0257 EmptyThu May 20, 2010 10:04 pm
Hello all, new here. Just stumbled on this great forum and had to register.
The problem I am having is the Check engine light came on at wide open throttle last night. My Actron 9145 Scanner stated a code of P0257, description: Turbo boost sensor signal circuit problem. Last time i checked my car didn't have a turbo ? . If anyone could make heads or tails out of this I would appreciate it.
PostSubject: Re: 95 Riv problem code P0257   95 Riv problem code P0257 EmptyThu May 20, 2010 10:26 pm
First off, welcome!
Are you sure it's not P1257?
PostSubject: Re: 95 Riv problem code P0257   95 Riv problem code P0257 EmptyThu May 20, 2010 10:42 pm
First off, welcome!
Isn't that also a supercharger overboost code?
(Disclaimer: I'm running off of '98 codes, so maybe they trashed the whole heirarcy...)
PostSubject: Re: 95 Riv problem code P0257   95 Riv problem code P0257 EmptyThu May 20, 2010 10:44 pm
Yes P1257 is a "boost problem" code in a '95. P0257 doesn't exist.
PostSubject: Re: 95 Riv problem code P0257   95 Riv problem code P0257 EmptyThu May 20, 2010 11:32 pm
Right, and Mike doesn't think he has a 'turbo'...
Michael, do you have a "supercharger" you haven't told us about??
P.S. - Please fill out your "signature", so folks know what we're dealing with.
PostSubject: Re: 95 Riv problem code P0257   95 Riv problem code P0257 EmptyThu May 20, 2010 11:43 pm
Since this was posted in Supercharged Tech, and Mike has a '95, we can assume it's a Series I Supercharged.
Mike95
Mike95
PostSubject: Re: 95 Riv problem code P0257   95 Riv problem code P0257 EmptyThu May 20, 2010 11:58 pm
Forgot to go into preferences to attach my signature. Should be working now. Yes it is a 95 buick riviera supercharged the code shows up as P0257. Just checked it 10 minuets ago and still showing on the tool when i check read code option. Maybe my scanner is damaged in some way.
Abaddon what part or electrical item would spring P1257 code?
PostSubject: Re: 95 Riv problem code P0257   95 Riv problem code P0257 EmptyFri May 21, 2010 8:40 am
P1257 is a Boost Solenoid Fault. If you can be sure that this is what is, I can post a flow chart for you to check it.....
Mike95
Mike95
PostSubject: Re: 95 Riv problem code P0257   95 Riv problem code P0257 EmptyFri May 21, 2010 5:08 pm
Thanks for the offer. I can't be sure if it is the boost solenoid or not. Looking into placing a boost gauge to see if I am only getting 2-3 psi or the normal 6-7. That should hopefully tell me if there is a problem with it.
Also the check engine light went off today while driving home. Checked with the scanner and still shows the same code.Code has been cleared. Will try WOT again to see if the error code comes up.
PostSubject: Re: 95 Riv problem code P0257   95 Riv problem code P0257 EmptyFri May 21, 2010 5:19 pm
Well, here is the flow chart anyway of the boost solenoid. Hope it helps ya!
95 Riv problem code P0257 Boostflowchart
Mike95
Mike95
PostSubject: Re: 95 Riv problem code P0257   95 Riv problem code P0257 EmptySat May 29, 2010 12:31 pm
Thank you for the flow chart. Used it and found it is working correctly.
PostSubject: Re: 95 Riv problem code P0257   95 Riv problem code P0257 EmptySun May 30, 2010 2:37 pm
np wink Hope the system just "farted" and the SES light stays off.
» Glossary of RAF mission code names
» Pre-Season Ticket Code
» Problem with Power Cord
» How can i fix a priming problem?
» CombatSportSupply.com Coupon Code
