 FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999
Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 Empty
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyMon Nov 08, 2010 7:41 pm
Depends on the year. The later years ('98-99) fit those models, but the '95-97 Riviera control arms do not swap.
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyMon Nov 08, 2010 7:49 pm
ok. thanks for that.
btw if anyone is interested ill have the formula in a week or so to fab up delrin bushings for the rear arms.if someone wants a set let me know. just as soon as i come up with the dimensions and all that.
it looks like the rears are the same for first gen and 2nd.
Merit : 135
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyWed Nov 24, 2010 10:50 pm
I'm weighing some options on control arms as I prepare for a 1998 cradle swap into my 1997. I have a set of not-bad looking control arms off a 2000 bonneville which, to the best of my knowledge, are the same as the 1998-99 riv arms.
I've read through this thread and unless I'm misunderstanding, you guys are saying you can replace the bushings in the 98-99 front control arms? Where do you get the bushings from? At rockauto, I see they have the full dressed control arms available for 98-99, but I don't see any bushings at all. They show up for the 1997.
One thing I'm really trying to investigate is whether or not the back bushing on the 98-99 front arm is the same as the 97 one. Obviously the front side is totally different but the back one looks the same to the naked eye. If that is actually the case, there's a very good chance that the poly bushings that zzp sells for the w-body's can fit the rear location on those control arms. That is provided rockauto is accurate about the part numbers for those bushings on the 1997 riviera control arms - they are the same part number as what the w-body's have. Raybestos part# 5651163
I guess I can dig around the bonneville forums to see if they have any such info but that kind of adds more confusion since they aren't necessarily year-for-year on suspension equipment with a riviera either.
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyWed Nov 24, 2010 10:54 pm
Ask billboast,on the bonniepro fourm,he just did all that you want to to his buick regal
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyWed Nov 24, 2010 11:52 pm
billboost
probably one of the top 5 knowledgeable 3800 guys around.
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyFri Nov 26, 2010 9:28 am
agree talk with bill.
Also, i have some of the rear lca bushings brand new if you want them. Cover shipping is all i ask. You can then comapre them with what you have now.
FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 Dsc_0110
Merit : 135
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyFri Nov 26, 2010 10:18 pm
I think this is a useful place to put this since this topic includes repairing control arms.
I took my arms from the 2000 bonne and sandblasted them. Excellent results - they look brand new
Photobucket
what I started with - looks like a CV joint took a shit all over it
Photobucket
I cleaned that up with solvent and a wire brush
I would have been fine with that but then I figured what the hell. I had a 60lb bucket of blasting sand not getting used anymore.
Photobucket
before & after
Photobucket
both done
Photobucket
woops! don't shoot yourself with it
95rivy
95rivy
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptySun Mar 06, 2011 7:55 am
Finally got around to do my front bushings.. Ordered the moog kit with both bushings. The front bushing came out with little trouble with an air hammer. The back bushing well thats a different story, but got it done. Thanks to a press and some sockets, then a vise. I wish i had the time to take pics of the job, but i was at my buddies shop and had someone waiting to get in.
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptySun Mar 06, 2011 8:28 am
I feel your pain. I wouldnt wish that job on my best friend.
Merit : 135
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyMon Apr 18, 2011 4:46 pm
You guys with a 1998/1999 FSM, what's the torque specs for the control arm to cradle mount points (the control arm bushings)?
thanks!
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyMon Apr 18, 2011 5:20 pm
Dude, you could have just called me man.........wtf FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 Icon_evi
Front Bolt = 93 ft/lbs
Rear Bolt = 117 ft/lbs
The "proper" way to do it is put the bolts in....don't tighten. Install the ball joint-to-knuckle and sway bar links. Lower the car (with control arm bolts loose). Tighten the the rear control arm nut first, then the front. GM says to do it this way......lol
Merit : 135
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyMon Apr 18, 2011 5:48 pm
Makes sense as the control arms must have a sort of home position where the outside of the bushings should be tightened against the inside of the brackets, no?
thanks Scott
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyMon Apr 18, 2011 7:08 pm
Nice post Codith!
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyTue Apr 19, 2011 8:58 am
thanks Scott
Basically yes. You do it this way to ensure that the trim height is the same from side to side.
Merit : 135
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyTue Apr 19, 2011 6:50 pm
FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 CIMG3217
Left - 1997 Right - 1998/1999
just posting the pic for reference
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyTue Apr 19, 2011 11:06 pm
any weight difference?
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyWed Apr 20, 2011 4:42 am
no there shouldn't be any difference in weight .
Merit : 135
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyThu Apr 21, 2011 12:02 am
I didn't weight the two but I'd say they're about the same based on what they felt like in my hands.
The Roadmaster
The Roadmaster
Name : Carl Alexander
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyTue Mar 20, 2012 8:42 pm
Do you still have that 97 off of your car? Would you be willing to lend it out for a bit?
Merit : 135
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyWed Mar 21, 2012 9:11 pm
Yes but I'll need it back at some point. I kept it so that I could confirm fitment of the w-body poly bushing for the back because I believe it could be the same size. I haven't gone and done that yet so it sits. If you want to barrow it for something, cool. What are ya gonna do?
The Roadmaster
The Roadmaster
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyWed Mar 21, 2012 10:18 pm
I'm going to pound some pavement with it in hand. There are some suppliers around here that I would like to go visit and see if there isn't another application that works. There may be a like application without a GM part number for another vehicle or piece of equipment.
I did some work for McLaren Performance locally, I'm sure one of those guys would have an idea or 2.
Here's their website: http://www.mclarenperformance.com/eportal/default.aspx
I doubt an obsolete part ever held them back from anything.
The Roadmaster
The Roadmaster
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyThu Mar 22, 2012 10:24 am
Turtleman .... look for a PM, we're going to go in a different direction with this.
For anyone else following this thread, if you would kindly advise me of any other vehicle models & makes that were affected by the Amcast parts void we may have a solution. I know some of you have posted issues with the 98-99 rear bushings not being available. Dimensions of the bushings is helpful, but a control arm with the bushings is better yet. You'll get your arm back.
I have contacted a manufacturer that has shown interest in providing these bushings for us ... just need to do some volume to make it go. I have the manufacturer following this thread so they will be up to speed in no time. We need to get them samples of the obsolete parts.
Affected by the bushings for 97 Riviera include 97 Park Avenue (some models) and 97 Olds Aurora. If you know anyone on the Aurora forum they may want to get in on this once we're past the planning stage, which is where we're at now. Need to generate some interest in this project to make it cost effective.
rk0ehn
rk0ehn
Name : Christian Rolf Köhn
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyMon Apr 02, 2012 8:32 pm
Does the 1997 Regal's control arm fits the 1996 Riviera?
On the rockauto.com site they seem to be pretty much the same as the 96 Riviera scratch
I do remember seeing those listed under 1996 Riviera but they no longer list them, they were the MEVOTECH Part # MS20329 for the left side and the MEVOTECH Part # MS20328 for the right side.
FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 Untitl10
I assume the 97 Riviera's control arm fits the 96's, but rockauto shows the control arm as being from the 1998 headbutt
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyMon Apr 02, 2012 11:23 pm
I am still amazed that GM expects us to buy a new arm whenever the original takes a crap!? Any one who has tried to replace either the vertical or the horizontal bushing themselves knows what I'm talking about.It's a f.....g joke.
PostSubject: Re: FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999   FAQ: Lower Control Arms & Bushings 1995/1996/1997/1998/1999 - Page 5 EmptyTue Apr 03, 2012 11:53 am
By the time you add up the price of the bushings and ball joint, the complete arm is not a bad deal, and saves a ton of labor. I did both sides and the car rides beautifully after.
Not that I agree with the principle - you should be able to service wear items, but it's not so bad.
I bought the complete GM arms from monsterpartsonline.com, I think the price was around $200 each at the time. I know it's more than the parts alone, but there was much less labor involved in swapping them out.
Page 5 of 9Go to page : Previous  1, 2, 3, 4, 5, 6, 7, 8, 9  Next
» Rear Lower Control Arms
» RZR S sloppy frontend
» Arctic Cat Arched Lower A-arms!!!
» Light Racing UCA Group Buy in the Blue Room 1/26-2/26
» control arm bushings
