| Write-Up: Replacing Belts and Pulleys | |
Name : Dave Age : 59 Location : In The AZ Oven Joined : 2007-01-17 Post Count : 4502 Merit : 44
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sat Aug 29, 2009 12:11 am | |
| No issues with my Gatorbacks after a year. |
Name : Derek Age : 47 Location : Reading, MA Joined : 2007-01-31 Post Count : 7717 Merit : 109
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sat Aug 29, 2009 9:15 am | |
| - 1998 Riv wrote:
- No issues with my Gatorbacks after a year.
I wasn't meaning to imply that there's anything wrong with gatorbacks, they are made from high quality rubber. It's just the little belt nubbies can have a negative effect when you get into tiny pullies and you are nearing the loose side of your tensioner, where the Gates belts with solid ribs and high quality rubber will grip just that little bit extra. In stock and near-stock installations the Gatorbacks should be fine. |
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sat Aug 29, 2009 9:16 am | |
| - Mikel wrote:
- Thank you guys. I just did my belts - The engineer who designed that motor mount should be hung from a certain part of his anatomy
 You got that right. I noticed on an '04 LeSabre I just worked on, the front motor mount is completely changed to a bottom-mount style, and the belts are free. |
BMD Aficionado
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sat Aug 29, 2009 1:57 pm | |
| What motor was in that LeSabre Derek? |
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sat Aug 29, 2009 2:14 pm | |
| 3800 of course! I advise all my near family members to buy 3800 powered cars... |
BMD Aficionado
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sat Aug 29, 2009 2:23 pm | |
| Slightly offtopic, but how much modifying would one need to do if one wanted to put in a 3800 with the bottom style motor mount in a Riv? |
Name : robotennis Age : 58 Location : las vegas Joined : 2007-12-17 Post Count : 5561 Merit : 142
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sat Aug 29, 2009 3:40 pm | |
BMD Aficionado
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sat Aug 29, 2009 4:39 pm | |
| I was just curious if someone needed a new motor and would prefer to put one in that is less difficult to replace the belts, how much modifying would it take to put in a 3800 motor with a bottom style motor mount in a Rivieras' engine bay. |
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sat Aug 29, 2009 10:02 pm | |
| beats me? i did not know that u had to remove the mount to replace the belt on a series 2? not so on a series 1 |
L67 Aficionado
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sat Aug 29, 2009 10:10 pm | |
| - BMD wrote:
- I was just curious if someone needed a new motor and would prefer to put one in that is less difficult to replace the belts, how much modifying would it take to put in a 3800 motor with a bottom style motor mount in a Rivieras' engine bay.
Probably more than its worth doing since you only have to change the belts every 100,000 miles or so if theyre properly aligned. |
Name : Rick Location : Lancaster, MA Joined : 2008-09-13 Post Count : 6222 Merit : 112
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sun Aug 30, 2009 7:23 am | |
| There are pic's on here somewhere where James removed the upper mount completely and fabbed up a lower mount for the whippled engine. I tried to find that write up but couldn't. |
BMD Aficionado
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sun Aug 30, 2009 2:40 pm | |
| - L67 wrote:
Probably more than its worth doing since you only have to change the belts every 100,000 miles or so if theyre properly aligned.  , but if you were gonna throw a new motor in there anyway, why not install one where the belts are free of the mount. Thanks for looking for that write up Rick, it would be interesting to see what was done. On a secondary point. Do all the pulleys loosen clockwise or are some different?
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sun Aug 30, 2009 2:43 pm | |
| On the series ii the tensioner pulley uses a left-handed threaded bolt. Not sure how the series 1 does it. |
BMD Aficionado
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sun Aug 30, 2009 3:22 pm | |
| If I am not mistaken, isn't there a fourth pulley that uses a right-handed threaded bolt? |
L67 Aficionado
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sun Aug 30, 2009 3:23 pm | |
| - BMD wrote:
- If I am not mistaken, isn't there a fourth pulley that uses a right-handed threaded bolt?
I believe its the lower idler pulley by the crank. |
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sun Aug 30, 2009 3:28 pm | |
| It depends if your talking series1 or 2 engines, i believe. There is a diagram on here for all the pulleys on a series2 and the rotation of the mounting bolts. |
BMD Aficionado
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sun Aug 30, 2009 3:32 pm | |
| Series II. Sorry for the questions, just read Jacks great  write up. It contains all the answers one might be looking for. Thanks guys.
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sun Aug 30, 2009 3:45 pm | |
| I followed that write up to do my pulleys and belts. Excellent help but be careful, the illustration regarding the A/C and some other pulley are incorrect. Otherwise it served me well and I got the job done in about 2.5 hours taking my time. |
Mikel Enthusiast
Name : Mikel Age : 42 Location : New Haven, CT Joined : 2009-07-12 Post Count : 157 Merit : 2
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Sun Aug 30, 2009 8:39 pm | |
| - Rickw wrote:
- I followed that write up to do my pulleys and belts.
Excellent help but be careful, the illustration regarding the A/C and some other pulley are incorrect. Otherwise it served me well and I got the job done in about 2.5 hours taking my time. That's about as long as it took me. Having to lift the engine, remove motor mount, motor mount bracket and power steering pump... To replace a serpentine belt is asinine. I was doing some work on my friend's 98 Riviera and I told him "hey, since we are here, why don't you run to the store and buy new belts? It will take two minutes to replace them!" How wrong I was  |
RivGuy Member
Name : Bob Norton Joined : 2009-06-14 Post Count : 71 Merit : 0
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Mon Aug 31, 2009 9:00 am | |
| I would like to know, when replacing the easy pulleys, do you have to have special puller to get the pulley off the shaft? Thanks for info about left handed threads. Mine is a 96 and has a regular 15mm bolt. RivGuy MOcarGuy@aol.comThanks |
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Mon Aug 31, 2009 9:29 am | |
| no. it slides off..the pulley takes a through bolt ... |
Sweepspear Fanatic
Name : Dale Age : 58 Location : Minneapolis, MN Joined : 2008-11-04 Post Count : 386 Merit : 11
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Fri Oct 09, 2009 4:40 pm | |
| I had to replace my water pump, so wihile I was there I replaced the pulley behind the motor mount bracket. I found NAPA part #NBH 38007, (made by Gates) to be identical to what I assume was the pulley GM installed Sept. '95 when my car was built. I found the motor mount suprisingly easy to remove and replace. But that lower clamp on the lower radiator hose which I also replaced is another matter though.  |
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Fri Oct 09, 2009 4:45 pm | |
| That lower clamp is easily removed with the proper clamp removal tool. Unfortunately most people don't have that tool unless you make your living doing these repairs. I bought one several years ago out of frustration and it has saved my arse several times. |
Sweepspear Fanatic
 | Subject: Re: Write-Up: Replacing Belts and Pulleys Fri Oct 09, 2009 5:02 pm | |
| - Rickw wrote:
- That lower clamp is easily removed with the proper clamp removal tool.
Unfortunately most people don't have that tool unless you make your living doing these repairs. I bought one several years ago out of frustration and it has saved my arse several times. I'm sure that would have made it much easier. I actually checked Harbor Frieght in fact to see if I could pick up a cheap pair. What made worse was the tangs you squeeze were on the bottom side so, I had to go at it blindly. I thought I was going to end up pulling the radiator at one point. It looked like for ease of assembly, GM placed a short section of hose on the radiator before it was placed into the car, then it was mated up with the hose from the block once the radiator was installed. 4 clamps total for 1 hose. |
| hmm, pair of pliers was ... umm ... difficult? but it worked. What's the clamp removal tool look like Rick? I'm interested. |
 | Subject: Re: Write-Up: Replacing Belts and Pulleys  | |
