 Intercooling / Aftercooling
85fieroGT
Merit: 0
PostSubject: Intercooling / Aftercooling    Tue Jun 22, 2010 10:54 pm
What if any options are there for this (95 Series 1 SC) engine to drop the Air Charge Temp?
Merit: 172
PostSubject: Re: Intercooling / Aftercooling    Wed Jun 23, 2010 7:58 am
That's a tough one. One way might be to adapt an M90 blower to fit the Series I (not simple), then modify a Series II intercooling kit to work. Lots of time and money would be involved, imo. But the result would certainly be unique.
More on using the M90 with Series I:
http://rivperformance.editboard.com/series-i-engine-transmission-f13/faq-m90-blower-in-place-of-m62-t4338.htm#8859
- John R. White, Boston Globe
Merit: 16
PostSubject: Re: Intercooling / Aftercooling    Wed Jun 23, 2010 8:11 am
One question,WHY? bonk
Merit: 172
PostSubject: Re: Intercooling / Aftercooling    Wed Jun 23, 2010 8:16 am
Intercooling = less knock for running more boost.
Merit: 14
PostSubject: Re: Intercooling / Aftercooling    Wed Jun 23, 2010 12:07 pm
Get meth injection kit... same result isn't it?
jamie
Merit: 1
PostSubject: Re: Intercooling / Aftercooling    Wed Jun 23, 2010 12:11 pm
[url]
Not for these people. lol.
Merit: 172
Merit: 96
PostSubject: Re: Intercooling / Aftercooling    Wed Jun 23, 2010 12:29 pm
[url]
I have spent the better part of 2 years investigating, looking into and studying the effect's, positive or negative, regarding the use of water/meth to help the engine and save all the labor of installing an intercooler. I kept coming up with peoples negative responses to using meth, over and over again. Never quite knowing why 99% of the people that know better are against it.
NOW, I FINALLY KNOW WHY. I WAS DOING MY RESEARCH IN THE WRONG AREA'S.
Thank you for saving me from this horrible fate.
Might be fun for a while, but............................
TheNewEra95
Trainee
Merit: 1
PostSubject: Intercooling?   Mon Jul 19, 2010 12:13 pm
I've been looking around....and I haven't seen anything about Intercooled 95 riv's, so I was planning on giving it a shot...buy a cheap kit and do it myself....
Question:
How much gain will I see in HP?(if any) twisted
Merit: 87
PostSubject: Re: Intercooling / Aftercooling    Mon Jul 19, 2010 12:45 pm
none. In practicality. There is no inter-cooler for the 95 SC. You can't raise the SC because it bolts into the alternator bracket, among other problems. There was a thread around somewhere where I talked about it. A custom job has been done on a Bonneville, but the heat exchanger had to be stuck inside the LIM itself. All of it would have to be custom, and nothing about it will be cheap.
» Intercooling / Aftercooling
