 Write-Up: Blower Motor Control Module Replacement
Write-Up: Blower Motor Control Module Replacement - Page 3 Empty
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyWed Feb 19, 2014 8:33 am
The only Head schematics I have are what I've posted for you, and one's for the Sunload sensors and passenger heater control. You should be able to diagnose your problem with what I've given you so far.
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyThu Feb 19, 2015 2:00 pm
Great write-up.  Helped me figure out where this was and diagnose it as the problem.  Took me about a half an hour to get changed out and now I have blowing heat again.  Man was it cold last night and this morning with no heat blowing in the car.
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyThu Feb 19, 2015 10:35 pm
I went thru a winter in Chicago with no heat due to a blower module out in the riv. It really sucked. I had to scrape inside the car. That's what got me to rivperformance
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyFri Feb 20, 2015 12:06 am
...wow...in Chicago with no heat Ruben?......man.....
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyFri Feb 20, 2015 11:13 am
Yep. I would get to work after an hour drive with hypothermia. I figured it out finally and got a new module at the dealer to install. Its a pain working under the dash to replace it. Thanks to this forum I figured out the problem
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyMon Mar 02, 2015 9:07 pm
My turn...
First start yesterday morning and I had no air; warm or cold. No signs of life from the fan motor.
Thanks, Scott, for the write up.
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyMon Mar 02, 2015 11:31 pm
If you can wait for it, try finding a used OEM part - mine was $30. These modules either go bad or last forever, it seems. If you buy from RockAuto: $130, GMparts Direct: $150, dealer: $290.
It's really easy to swap. Best of luck.
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyMon Mar 02, 2015 11:57 pm
If I'm not getting any air or sounds at all, it's most likely the blower motor, right? And not the control module?
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyTue Mar 03, 2015 7:20 am
Difficult to say. Both can result in motor not working. I'd replace the module first, unless you can remove the motor and test it.
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyTue Mar 03, 2015 8:36 am
Didn't I specifically tell you to put 12v to the Blower Motor? (not in this write-up) You can do it right in the car without removing it. I've used a Battery Jump Box with some jumper wires before....
Or better yet, get yourself a 194 marker light socket with a bulb. Unplug the blower motor. Put the wires of the light socket into the connector for the blower motor. Turn the heat on HIGH. The bulb should light up BRIGHT. The lower fan speed you go, the dimmer the bulb will get. This would tell you if the BMCM is functioning or not. Or you could use a Voltmeter. 12V being HIGH setting, roughly 6V being LOW, with an even "ramp" in between.
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyTue Mar 03, 2015 8:45 am
Good idea testing the motor with 12v. Then do the lamp test on the module to rule out wiring/fuse/climate control as issue. thumbsup
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptySun Mar 08, 2015 12:05 am
I flew over to Psycho Sexy's hideout today.
Write-Up: Blower Motor Control Module Replacement - Page 3 Captur13
Swapped out the BMCM from his parts Riv and sha-blam; air system is back online.
MONTANARIV
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptySat Jun 02, 2018 12:23 pm
Hi all - my fan in my 97 just stopped working at any speed driving out of the parking lot. Checked fuses, all good. Guy at NAPA whose owned 3 (2 '95s and a '99) said its likely the blower motor or the resistor. He had the blower motor so figured I'd try that first. What a PITA it is taking the blower out without removing the module first! smile Ah well, live and learn. Ended up having to remove the module anyway as I couldn't unhook the wires from it to let the motor drop. And it turns out, its not the blower anyway. GM module on order from Rock Auto for $120. Thanks for all the writeups - just like to recommend that if anyone needs to replace the blower motor, pull the module first - will make life much easier - cheers!
Merit : 111
PostSubject: Re: Write-Up: Blower Motor Control Module Replacement   Write-Up: Blower Motor Control Module Replacement - Page 3 EmptyThu Aug 22, 2019 2:12 pm
Guys,
              In case anyone is having a problem with their blower motor speeds, Rockauto is having a wholesaler closeout on on the BWD/Niehoff RU1234, which is the blower motor module for the 98-99 Riviera.  It's only 23.79!  All the other choices are 100.00 or more.  They have 5 left.  I figured what the hell, for 23.79, I'll order it.
I usually leave my climate control on Auto and just select the temperature I want.  I first noticed a problem this past winter as the blower didn't come on when it should have.  Usually when the engine warms up sufficiently, the blower activates and all is well.  This time, it didn't come on until very late and then it stayed on.  As I started using the A/C this Spring, the blower would come on full speed, then quit, and then randomly oscillate between low and higher speeds, then quit, then repeat.  About 5 minutes into my trip, it would stay on, and occasionally quit, then start again.  This solved my problem.  Box says Made in the USA.
https://www.rockauto.com/en/catalog/buick,1998,riviera,3.8l+v6+supercharged,1303322,heat+&+air+conditioning,blower+motor+control+module+/+resistor,6557
» XP1000 vs Mavrick
» Spectrum JR Module Improvement
» Micron Radio Control
» Briggs 5hp block
» Turnigny 1230 motor
