 Transmission Modular valve
Transmission Modular  valve Empty
PostSubject: Transmission Modular valve   Transmission Modular  valve EmptySat Jul 24, 2010 1:40 pm
What do you think, about the valve that adjusts the pressure? Good or bad? I put one on my car, trans shifts like a dream... I would say, it's running about 90% pressure.... nervous
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptySat Jul 24, 2010 2:55 pm
If you mean an adjustable vacuum modulator, yes, they are good.
I've put them on all my transmissions that used vacuum.
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptySat Jul 24, 2010 3:05 pm
That's it ..
Merit : 122
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptySat Jul 24, 2010 11:20 pm
yup, they are handy to improve things. For anyone wondering, the part for the 4t60e, is ATP part# JX70 ... but its sad I know that off the top of my head...
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptySat Jul 24, 2010 11:23 pm
??why? are they not available for the 95s?
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptySun Jul 25, 2010 2:08 am
Is this a diifficult mod to do? What is involved?
Merit : 122
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptySun Jul 25, 2010 7:44 pm
Easy. Just one 10mm bolt(i think), take out the old "giant" modulator, stick in the new, re-bolt the bracket, and done. Where the vacuum connects is where you stick a small flat head screw driver to adjust your line pressure.
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptySun Jul 25, 2010 7:51 pm
whats special about it? i coulda sworn there was nothing available for the 95 tranny?
Merit : 122
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyMon Jul 26, 2010 12:13 pm
Its special cause it is adjustable; you can firm up your line pressure for crisper shifts. Helps remove the Buick "lazy transmission syndrome" The stock one is non adjustable.
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyMon Jul 26, 2010 12:39 pm
is this in any way harmful to the tranny?
Merit : 122
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyMon Jul 26, 2010 12:50 pm
Not really, the only thing is the line pressure is temp dependent. So if you up the pressure, and its a cool morning, it might be a bit of a jolt shifting from park to say reverse. As far as harm to the tranny, the higher line pressure makes the shifts happen a little quicker, so no hunting, and less wear on the plates as I understand it.
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyMon Jul 26, 2010 1:06 pm
cool. can the valve be incrementally adjusted?
Merit : 122
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyMon Jul 26, 2010 1:27 pm
Its a flat head screw inside the valve. Clock-wise is firmer, counter is "un-firmer"
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyMon Jul 26, 2010 1:41 pm
ok. im getting one. "un-firmer" nevah hoid dat one before. im gonna use it.
98SuperRiv
98SuperRiv
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyMon Jul 26, 2010 1:57 pm
how much is one of those transmission modular valves? and can i get one from the autozone or do i have to go through summit racing or jegs?
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyMon Jul 26, 2010 2:07 pm
Again, it's an "adjustable vacuum modulator"... and it should be a standard item in any good, independent parts store. I first installed one in the Turbo 350 in my '72 Cutlass, approximately one million years ago. wink
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyMon Jul 26, 2010 9:25 pm
You can't use one,no vac. laughat
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyThu Sep 16, 2010 1:44 pm
does anyone have a part # for the adjustable vacuum modulator ? i cant find my year available at the local shops.
Merit : 122
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyThu Sep 16, 2010 2:22 pm
As said before, mine is ATP part# JX70. I dunno if you can get it anymore though.
If at the parts counter you could just ask to see(and hold) their entire selection of modulators for the 95 sc riv. Then see if it has an adjustable screw in the hold where the vacuum line goes. Try these ones: FRAM Part # FM2333
AIRTEX / WELLS Part # 7R1004. For 20$ it can't hurt to see.
PostSubject: Re: Transmission Modular valve   Transmission Modular  valve EmptyThu Sep 16, 2010 7:09 pm
thanks K
» Transmission & gear-case fill, drain and oil
» Transmission problems
» valve adjustments
» Make a 12-Speed Transmission from a 6-Speed Transmission?
» Transmission with Side input and output shafts?
