 ABS failed
Go to page : Previous  1, 2
Merit : 177
PostSubject: Re: ABS failed   Thu Jul 29, 2010 2:24 pm
Eldo wrote:
Scott, if he pulls all the ABS/TC fuses, shouldn't he have normal brakes?
Yep. As long as every single ABS and TC fuse is pulled, he will have "normal" brakes with all the idiot lights on lol. But, it'll work.
97 park ave
Merit : 21
PostSubject: Re: ABS failed   Thu Jul 29, 2010 2:29 pm
nothin a little black electrical tape wont fix wink , either that or pull the dash quick and pop the lights out...
Merit : 133
PostSubject: Re: ABS failed   Fri Jul 30, 2010 2:11 am
YO MUDA wrote:
The HDRZ/STOP fuze is good. When I drive it from a dead stop,normal acceleration, and I get to around 50, their is a loud thud, but the car is still driving fine. Then somewhere between 50 and 55 the car starts bogging down and it fells like the breaks almost locks down. Then it drives normal for a few minutes and does it again. It kinda reminds me of someone pulling up a hand break. Do ya think this car may be haunted? LOL
Did you check the transmission fluid level/quality lately?
Merit : 102
PostSubject: Re: ABS failed   Sat Jul 31, 2010 9:21 pm
No such thing... wink
Aaron also makes a good point: Has Jimi tried the Traction button on the dash??
Applying the brakes should be the TC rather than the ABS, and deactivating the TC should let him drive it until it's repaired.
PostSubject: Re: ABS failed   Sat Jul 31, 2010 11:25 pm
As long as Traction Control lamp is on, the system will be deactivated. Doesn't matter if the PCM commands it, or you use the switch.
YO MUDA
PostSubject: Re: ABS failed   Sat Jul 31, 2010 11:30 pm
Just got back in town. I'll mess with it some tomorrow and tues im running it by the dealer to get the codes checked again. Thanks for all the help, im still not giving up on her.
PostSubject: Re: ABS failed   Sun Aug 01, 2010 12:36 am
If they come up with the code you got earlier you'll need to know:
Is it the Pressure Switch in the Pressure Modulator Valve thats gone bad or is it a bad signal / wire to the EBTCM or a bad EBTCM.
Big difference in prices for either of the 3 possibilities based on that previous code.
Wire or connector repair is inexpensive.
EBTCM is much more expensive, can be bought used, but a bad pressure switch inside the Pressure modulator Valve will be the most expensive, But, still probably can find one used. IDK
One thing a Dealer may be able to do with the GM TECH 2 diag tool is to try and activate that switch in the Modulator Valve. I'm not sure if the tool is capable, but if any tool is, it would be that one.
Merit : 102
PostSubject: Re: ABS failed   Sun Aug 01, 2010 2:31 am
Nowhere has he said that the TC lamp is on...
YO MUDA
PostSubject: Re: ABS failed   Sun Aug 01, 2010 11:18 am
albertj I did check the tranny fluid. The level was fine and it was clean. The TC lamp never came on. I'll put the fuses back in before they run the codes. The first place that did the codes was a shop I ussually dont deal with. I got my money back from them. The place Im going to Tue is a Buick dealer, hopeing I'll get better results and explanations from them. I'll let you know what I find out. Thanks to all you guys for your replys and help. This is a good place to be a part of.
Merit : 133
PostSubject: Re: ABS failed   Sun Aug 01, 2010 11:20 pm
OK, didn't catch you'd checked fluid. just a thought... We'll see what dealer says, hopefully you get a tech who works on and likes the older cars...
ABS failed
