| | KR change with traction control button? | |
| | Author | Message |
bmoeller Special
Name : Brian - 99 riv Location : midwest Joined : 2010-07-23 Post Count : 5 Merit : 0
| Subject: KR change with traction control button? Sun Jun 12, 2011 12:21 pm | |
| On my 1999 riviera - Just finished installing 180 t-stat, Autolite 104's, PRJ wires, gutted airbox, 3 inch downpipe, and ZZP pulley system with 3.5" on it. Scanned it, and KR goes all over the place, up to 8!
On a whim, I turned off traction control, and KR went down to 2 or 3 under acceleration, which is still too much. Guess I'll be buying a 3.6" pulley.
Has anyone ever heard of KR being affected by the traction control?
Thanks! | |
| | | Mr.Riviera Expert
| Subject: Re: KR change with traction control button? Sun Jun 12, 2011 3:24 pm | |
| yes. when i have a lot of wheel spin and traction control is trying to pull timing to control it i will see KR spikes. When are you seeing this KR? top of 1st, top of 2nd? all the time?
If you are just seeing blips at the top of each gear thats not that bad for a 3.5 pulley in the summer.
I am going to assume you have all the maintenance items done on the car (fuel filter for instance) and you are running 93 octane.
_________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| | | bmoeller Special
| Subject: Re: KR change with traction control button? Sun Jun 12, 2011 8:52 pm | |
| I hooked up Genesys to the car and went for a drive...at idle, there was no KR, about 1-2 with casual driving, and up to 8 at WOT going through the gears.
After turning off the Traction Control, it would go up to just under 4KR while going through the gears under WOT.
I was never spinning the tires, so I was surprised the traction control made a difference.
| | | Mr.Riviera Expert
| Subject: Re: KR change with traction control button? Sun Jun 12, 2011 9:27 pm | |
| you shouldnt be seeing ANY KR at idle or with normal driving. Maybe you are getting false KR or else the motor just isnt running 100%.
what grade gas are you using? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| | | Northeast Member
Name : Joined : 2010-09-14 Post Count : 84 Merit : 1
| Subject: Re: KR change with traction control button? Mon Jun 13, 2011 10:49 am | |
| - bmoeller wrote:
- KR went down to 2 or 3 under acceleration, which is still too much.
3 degrees isn't that dangerous.... I've pulled 3 @ WOT when I was stock once or twice. 0 is nice, but I don't see you killing anything at only 3. What are you running for fuel (octane level)? Fuel pump performance adequate? Fuel filter clean? | |
| | | AA Administrator
| Subject: Re: KR change with traction control button? Mon Jun 13, 2011 11:44 am | |
| Did you scan the car before you made the modifications? If not, there might have been KR beforehand. This could be a maintenance issue, not related to the mods.
Were the conditions exactly the same between the scans with TC on and off? Same ambient temp, same location, same fuel? If not, there could be other variables to consider. Were you able to repeat the results for TC on/off to isolate it as the change that directly caused the decease in KR?
_________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| | | Abaddon Expert
| Subject: Re: KR change with traction control button? Mon Jun 13, 2011 7:34 pm | |
| 4* KR at WOT isn't going to hurt a thing...you're just gonna lose HP. Don't know why your seeing more KR with the TC on though. That doesn't make sense.... | |
| | | Eldo Expert
| Subject: Re: KR change with traction control button? Mon Jun 13, 2011 8:53 pm | |
2 thoughts:I have virtually the same engine mods and in warm weather I can get spurts of 5 degrees or so at WOT, and I'm usually running "Cali 91" octane, so you're in the ballpark. What's your octane and what was the weather like? Unless the car was really running badly, the front tires are gonna' break loose in 1st and either you or the TC have to prevent spin... Depending on when you were looking at the readout, I suspect that you might be seeing less KR with the TC off because your right foot is automatically performing traction control duties. | |
| | | Sponsored content
| Subject: Re: KR change with traction control button? | |
Similar topics | |
