 Weird noise
DarkVader
PostSubject: Weird noise   Mon Aug 16, 2010 1:01 pm
theirs is this weird noise and rough pulsating feeling coming from the right front brake, i bought a new pad and rotor to be installed saturday, could their be any other problems?
PostSubject: Re: Weird noise   Mon Aug 16, 2010 1:25 pm
This is called brake judder. It happens when you get pads too hot, too fast. The pads sort of melt and smear onto the rotor, causing the vibration. Usually it affects the two fronts, or the two rears, or both.
Usually it's best to replace rotors and pads in pairs (pads are sold in sets of 4 for a pair of wheels). It may seem like only the right front, but it could be both sides, or the rears may be contributing as well.
If you're sure it's the front wheels, I'd get another rotor and replace both sides, and new pads of course.
Are you hard on brakes? If so, you may want to upgrade to some better pads. The problem will usually come back in 20-30k miles unless you change the pad compound.
More on judder and how to fix it:
http://rivperformance.editboard.com/brakes-suspension-f6/identifying-and-correcting-disc-brake-judder-t5500.htm
Weird noise
