| Repairing headphones? | |
| Subject: Repairing headphones? Wed Sep 15, 2010 2:26 am | |
| I've got an older pair of Sennheissers with a speaker out. Dropped on the floor one too many times. Maybe a broken solder joint? Need some advice - be a shame to send them back to Sennheisser for repair for a problem I might be able to fix in a few minutes.
Oh yeah, I need instructions on opening these puppies up too. Looks like they could have been designed to keep the owner from getting in there and trying to do their own work. | |
| Subject: Re: Repairing headphones? Wed Sep 15, 2010 9:04 am | |
| Could be the plug or strain relief. Can you wiggle the cord at either end and get any response? Phones are simple, should be able to diagnose once you get them apart. What model? _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Repairing headphones? Wed Sep 15, 2010 3:29 pm | |
| HD 545 The cable is replaceable on these (and apparently that's a good mod). I swapped the ends around and the bad side stayed bad and the good side still worked. It appears that the cable connector in the earpiece is a weak point on Sennheisser headphones, most likely that's where my problem is. - Quote :
- Does anyone know how to disassemble a pair of HD495's? My brother managed to break his pair and it seems the problem is in the connector (the cable is fine). From what I can see, the earcup can be disassebled, but I am a little unsure of who much force it will tolerate without breaking. Are there any tricks I should know about here?
- Quote :
- Don't have those myself but are they not typical?
I mean, snap-off pads, screws under that, and a clip inside on the cord's strain relief piece?
If you are needing to subject it to stress to disassemble, heating the plastic a "little" should make it more flexible, less subject to cracking but I wouldn't think you'd need to do that. Link - Quote :
- I had posted a few posts down about the faulty cable connection. I read somewhere that someone disassembled the headphones and tightened up the springs that connect to the cables. I was wondering if anyone knows how to disassemble the headphone? I figured out how to get the velvet foams off by just plucking them out. But it doesn't appear that the plastic layer underneath it can just be plucked out. Seems to be locked in somehow. Any ideas? Thanks for any help!
Link Now I've just got to figure out how to open them up. | |
| Subject: Re: Repairing headphones? Wed Sep 15, 2010 3:39 pm | |
| Subject: Re: Repairing headphones? Wed Sep 15, 2010 8:28 pm | |
| Interesting - unfortunately 545's have an oval housing. Twisting won't work. Thanks for the suggestion. They've got to come apart somehow, but I haven't even got the velour part off yet. | |
| Subject: Re: Repairing headphones? Wed Sep 15, 2010 9:22 pm | |
| The housing may be oval, but are the drivers? I could still see the bayonet system as an option. Wouldn't hurt to try.
Maybe try removing the ear pads - they usually slip off. Is there any clues underneath?
Another option, if the housing has "reveal" gaps, like door gaps, it may be a snap together assembly. Try inserting a small flat screwdriver in the gap and gently pry outward from the center. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Repairing headphones? Thu Sep 16, 2010 1:05 am | |
| I'll post pictures of my the 545's tomorrow. | |
97 park ave Addict
| Subject: Re: Repairing headphones? Thu Sep 16, 2010 2:02 pm | |
| i did a little research on this issue, it looks like you can replace the whole cable but you already said if you could fix it for cheap thats what you wanted to do. i scanned google for a bit and found this thread: http://www.head-fi.org/forum/thread/86786/sennheiser-hd545-vs-hd580
you can read all of it, but there is a post about half way down the page by "bill ward" that says that the problem isnt the cable, but the connector. another post a bit after that by "pp312" confirms that this is what happens with the hd 545's and if you spray a bit of "craig pro gold" on the male end and insert it a few times and repeat, that it will help the connection. i searched for the pro gold and the name has been changed to DeoxIT gold, heres a link to what it looks like: link
hope that helps! | |
| Subject: Re: Repairing headphones? Fri Sep 17, 2010 1:04 am | |
| I got the muff off - Where to go from here? The speaker is mounted on a plastic piece that rocks on these center pivots - I'm at a loss how to go further. 97 park ave - I guess that could be it - my gut tells me there's a problem inside somewhere. | |
| Subject: Re: Repairing headphones? Fri Sep 17, 2010 10:21 am | |
| Maybe some clues?
http://www.head-fi.org/forum/thread/403963/sennheiser-hd555-and-hd595-internal-comparison-shots _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Repairing headphones? Fri Sep 17, 2010 10:25 pm | |
| I ain't got no screws | |
97 park ave Addict
| Subject: Re: Repairing headphones? | |
