| Transmission Trouble, Slipping?? (Series I SC) | |
+33dreww Karma Hometown Hero L67 95rivy playa moldymac Straighteight BMD Rickw TheNewEra95 lionfish Mr.Riviera BKRIV riviera301240 Lucas deekster_caddy jamie BillBoost37 96RivSCMI albertj blown95riv zombiesarebad rivcop SC95Riv daveeif heyzelchi Blowin95 SilveR NO 4 EVR AA gosloriv 95_River 37 posters |
rivcop Amateur
Name : Kevin Age : 45 Location : Cincinnati, Ohio Joined : 2007-10-27 Post Count : 22 Merit : 0
| Subject: Transmission problem Sat Nov 17, 2007 12:23 pm | |
| EGR valve? Thats odd symptoms. I had to replace the EGR on my 95, but it always went into gear??? Modulator valve was bad too. | |
zombiesarebad Member
Name : Brian Age : 40 Location : Maine Joined : 2007-12-04 Post Count : 97 Merit : 0
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Tue Dec 04, 2007 5:29 pm | |
| how many miles on it, and had you ever changed the fluid before that? It sounds wierd but sometimes new fluid can make the transmission slip if there was already something wrong before, but was asymptomatic. To put it simply, the new fluid is more "slippery" and the bands and clutches inside the transmission don't hold as well afterward (because they were already worn out). | |
heyzelchi Amateur
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Thu Dec 06, 2007 4:56 pm | |
| I have 139 on it an it was the fist time I can the transmission fluid but I also notice that it buring anitfreeze | |
heyzelchi Amateur
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Tue Dec 18, 2007 8:06 pm | |
| ok I went to aamco and they told me that I need a new transmission the prices they were quoting was all over the place 1,800 to 2000 I know I could get someone to rebuild the transmission cheaper | |
blown95riv Special
Location : WNY Joined : 2008-06-20 Post Count : 9 Merit : 0
| Subject: Transmission Trouble, Slipping?? (Series I SC) Thu Jun 26, 2008 8:11 pm | |
| hi im new the this forum i recently purchased a 1995 sc riv and am having tranny issues.It occasionally slips heavily during WOT or after heavy driving which is than accompanied by the ses light.it almost seems like the car is dropping into neutral.It usually only does this until i take my foot off the gas and than works fine however today it would not go back into drive i was basically free revving it until i put it in park and back in drive and than it was fineThe tranny has a very slow leak which i dont think is the cause and it has about 167,000 im getting it scanned tomorrow but if you guys have any thoughts or may know the cause in the mean time i would really like to know thanks in advance | |
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Thu Jun 26, 2008 11:36 pm | |
| You have to find out what code is being set. Can't help much without it.
Although it kind of sounds like if the tranny has 167K on it and has not had a filter change/flush/fill, you're way overdue. Might want to get it done somewhere where they will use the new Dexron.
blown95riv Special
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Fri Jun 27, 2008 11:15 am | |
| just got back from mechanics its a qdm1 failure code p1640 iirc what exactly is the quad driver module and how would i go aboiut fixing this problem?also albertj the fluid does not look bad at all and the previous owner was a rabbi who was pretty meticulous with the car so im assuming that the tranny has been serviced in the past.i am however worried to do a drain and filter changeon a car with this many miles because my last car blew the tranny a couple hundred miles after | |
96RivSCMI Enthusiast
Name : Kenon Age : 38 Location : Wright City, MO Joined : 2007-01-23 Post Count : 123 Merit : 2
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Fri Jun 27, 2008 11:38 am | |
| Found this using google...
ALLDATA.com
DTC P1640 Driver-1-Input High Voltage Refer to PCM Power and Grounds for wiring view
Circuit Description The PCM contains chips called Output Driver Modules that provide 7 switchable ground outputs for operating solenoids, relays, telltales, and other devices. Each of these ground outputs has fault lines that feed back to the PCM's microprocessor. ODM #1 can also sense high voltage coming in which might damage the chip. DTC P1640 is used to monitor ODM #1's overvoltage sense line.
Conditions for Setting the DTC Test Condition Engine running at least 10 seconds.
Failure Condition Overvoltage is sensed for 2 seconds.
Action Taken When the DTC Sets
The PCM will illuminate the malfunction indicator lamp (MIL) when the diagnostic runs and fails. The PCM will record operating conditions at the time the diagnostic fails. This information will be stored in the Freeze Frame and Failure Records. Conditions for Clearing the MIL/DTC
The PCM will turn the MIL OFF after three consecutive drive trips that the diagnostic runs and does not fail. A Last Test Failed (current) DTC will clear when the diagnostic runs and does not fail. A History DTC will clear after forty consecutive warm-up cycles with no failures of any emission related diagnostic test. Use a scan tool to clear DTCs. Interrupting PCM battery voltage may or may not clear DTCs. This practice is not recommended. Refer to Clearing Diagnostic Trouble Codes in PCM Description and Operation. Diagnostic Aids Since an overvoltage at ODM #1 should also trigger DTC P0563, the diagnosis for DTC P0563 may be used if vehicle voltage is actually too high.
A loose or faulty connection at generator L terminal may cause DTC P1640 to set intermittently.
Test Description Number(s) below refer to the step number(s) on the Diagnostic Table.
If ignition voltage and IPC battery voltage are within 1.5 volt of each other, there may be a system voltage problem. If they are not within 1.5 volt of each other, find out why the PCM is different.
Checking if PCM ignition voltage is actually displaying system voltage.
1 Was the Powertrain On Board Diagnostic (OBD) System Check performed? -- yes- Go to Step 2 no -Go to A Powertrain On Board Diagnostic (OBD) System Check
2 Start and idle the engine. Using a scan tool note the Ignition 1 display. Compare this voltage to the voltage displayed by the vehicle message center. Are PCM and vehicle voltage readings different by more than the value specified? ---1.5 volts yes - Go to Step 3 no - Fault not present. Refer to Diagnostic Aids
3 Using DVM J 39200 measure voltage to ground on PCM fuse (installed).
Is voltage measured and the Ignition 1 voltages different by more than the value specified? ---1.5 volts yes - Go to Step 4 no - Perform Charging System Check
4 Check for high resistance in CKT 439. Repair high resistance if needed. Was a repair made to CKT 439? -- yes - Go to Powertrain Control Module Diagnosis for Verify Repair no - Go to Step 5
5 Check PCM terminal contact at connector C1 terminal 19 and connector C2 terminal 37. Repair terminal contact if needed. Was terminal contact repaired? -- yes - Go to Powertrain Control Module Diagnosis for Verify Repair no - Go to Step 6
6 Replace the PCM (Go to PCM Replacement/Programming ).
Is the replacement complete? -- Go to Powertrain Control Module Diagnosis for Verify Repair -- | |
BillBoost37 Junkie
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Mon Jun 30, 2008 2:56 pm | |
| QDM 2 IIRC covers the Boost control soleniod TCC lockup Evap soleniod And I forget if there's one more.
Figure that code is probably thrown from the TCC being commanded on and not locking.
I would suggest checking flluid level first. Then the condition of the fluid.
Has the transmission been serviced that you know of? aka drop pan, change filter and replace about 7 quarts of new fluid. | |
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Tue Jul 01, 2008 2:41 pm | |
| On these cars the TCC solenoid is just a plastic plug and wears out. A good tranny shop can get one made of billet aluminum. My 4T65E transmission TCC failed about 90,000 miles ago. While replacing I also replaced engine's rear main seal and as well put in hi-durability rebuild kit (bands). I have had the tranny flushed and filled twice (about each 40 K miles) since. I do not baby it but I don't race or thrash it either.
That TCC solenoid is a PITA to reach. But when you do replace it suggest you get an aftermarket billet one, not OE plastic. GM may have a billet one too, ask the parts folks, though.
jamie Fanatic
Name : Jamie Age : 36 Location : Truro, NS Joined : 2008-06-17 Post Count : 283 Merit : 1
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Fri Jul 18, 2008 8:52 pm | |
| I'm having this exact problem with my 95 riv'
Thanks for the information! | |
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Fri Jul 18, 2008 9:42 pm | |
| Keep in mind the 95 has the 4T60E. I don't know if the solenoids are the same. If they are, this should be it:
http://intense-racing.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=IR&Product_Code=GMH-TCCS&Category_Code=T | |
blown95riv Special
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Sun Jul 20, 2008 1:22 am | |
| Thanks for all the help guys the transmission is still doing it i havent had time to post on here in awhile,i turned up the adjusting screw on the vac. modulator to turn up the line pressure during part throttle in case it was a valve sticking or something but it didnt do much but tighten up the shifts i also noticed that it only slips when i break hard into 1st gear an than resume accelerating so im not 100% sure its the tcc solenoid | |
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Sun Jul 20, 2008 1:46 am | |
| there was a service bulletin about that, I think - might have to ask a dealer.
jamie Fanatic
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Tue Jul 22, 2008 3:33 pm | |
| Turns out my problem was all in the vacuum lines. I noticed some cracks in the old rubbers and one of the lines was split. I put some electrical tape to work, let the car idle for a bit and then took it for a drive. The engine light went out and my car shifts excellently now. | |
blown95riv Special
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Tue Jul 22, 2008 5:41 pm | |
| jamie do you know which vacuum line was causing the problem because i havent replaced them all theres a few still that are rotted | |
jamie Fanatic
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Tue Jul 22, 2008 7:13 pm | |
| I'll go take some pictures. It'll give me a chance to get the riv' online anyhow edit: Had to use imageshack, as I locked myself out of photobucket with wrong passwords. I put those two pieces of tape on and all has been well for a few days. I'm hoping that it was the issue. haha. and yeah, I've gotta touch up on both of those tape attempts. | |
95_River Amateur
Name : Brandon Location : Columbia, SC Joined : 2007-01-23 Post Count : 32 Merit : 0
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Mon Aug 25, 2008 4:13 am | |
| I really hate to pull this post back out but I wanted to update everyone! My Rivs tranny was gooing goooing gone. That is what made it sutter. New tranny and A/C compressor at a cost that was worth more than the KBB on the car. ($5400.00) It was worth it though. This car will be a classic! It's still in the family and is resting nicely in a garage beside the XLR. BTW AA, it took me a year to figure out then '94 joke! Ha ha your right! Jokes on me! | |
Lucas Enthusiast
Age : 41 Location : Washington, D.C. Joined : 2008-08-15 Post Count : 118 Merit : 1
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Mon Aug 25, 2008 7:54 am | |
| IMO KBB underrates a Rivi tremendously. | |
riviera301240 Special
Name : superchargered Joined : 2009-09-29 Post Count : 7 Merit : 1
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Wed Sep 30, 2009 12:12 pm | |
| Hey anyone no what hose or peice might be missing, I have a transmission leak on the driver side that dripps repeatly after the car sit when I put fluid into the trans it runs find anyone else had this promblen for a 1995 chrg. | |
BKRIV Enthusiast
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Wed Sep 30, 2009 12:27 pm | |
| (Hey anyone no what hose or peice might be missing, I have a transmission leak on the driver side that dripps repeatly after the car sit when I put fluid into the trans it runs find anyone else had this promblen for a 1995 chrg.)
From what you've described it sounds like it might be an o-ring or seal at the dipstick tube where it enters the case @ drivers side just behind downpipe. If you dont feel comfortable doing it yourself a tranny shop shopuld'nt charge you much at all for sticking one in for you just one bolt and slide it on, bolt might have even loosened up and just needs retightened...good luck! | |
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Wed Sep 30, 2009 12:30 pm | |
| Okay from were I was looking it dripps like its between the pan and driver wheel. | |
BKRIV Enthusiast
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Wed Sep 30, 2009 12:45 pm | |
| your transmission is the 4T60E, I'll send you a number to call where you might be able to describe the problem and get a gasket or seal sent to you, sounds to me like it might be in the valve body cover or side cover gasket area but the guy who's number I'm going to private message will help you more than I can...check your messages | |
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Wed Sep 30, 2009 1:38 pm | |
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) Wed Sep 30, 2009 1:58 pm | |
| It sounds like the outer axle seal is leaking. Although, since you have a 95, pull the vac line off the front of the transmission and make sure the diaphragm in the shift modulator hasnt broken and is leaking out. (easy to check)
A bottle of lucas stop leak should fix the seal leak if you dont have the $$ to have a shop pull the axle out. Check to see if there is transmission fluid pooling in the little lip where the axle goes into the transmission. _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: Transmission Trouble, Slipping?? (Series I SC) | |
