 Hello Everyone
GreenJeanS
GreenJeanS
Hello Everyone Empty
PostSubject: Hello Everyone   Hello Everyone EmptyFri Oct 01, 2010 11:35 pm
After lurking for quite a while, trying to learn all i could I figured why not join up, so here I am. Glad to have found the place!!!
PostSubject: Re: Hello Everyone   Hello Everyone EmptySat Oct 02, 2010 12:10 am
Welcome pimp
PostSubject: Re: Hello Everyone   Hello Everyone EmptySat Oct 02, 2010 12:47 am
Welcome, lets see some pics! cyclops
PostSubject: Re: Hello Everyone   Hello Everyone EmptySat Oct 02, 2010 5:00 pm
Hi GreenJeanS
PostSubject: Re: Hello Everyone   Hello Everyone EmptySat Oct 02, 2010 10:02 pm
Hello Lurker!!! lol
Merit : 20
PostSubject: Re: Hello Everyone   Hello Everyone EmptySat Oct 02, 2010 11:09 pm
Hello!! hi
PostSubject: Re: Hello Everyone   Hello Everyone EmptySat Oct 02, 2010 11:32 pm
Hello Everyone Hi Welcome to the site!
PostSubject: Re: Hello Everyone   Hello Everyone EmptySun Oct 03, 2010 12:26 am
Welcome, now where are the Pic's. Mandatory must have pic's. J/K
First question: Do you have a set of Factory Service Manuals.? If you have a Vat's problem all questions and ultimately most answers will come from the FSM for your year car, as each is slightly different.
And what makes you think you have a VAT's problem with a stalling issue.
Please add the mileage in your sig as well. Need to know how many miles are on the vehicle as well.
GreenJeanS
GreenJeanS
PostSubject: Re: Hello Everyone   Hello Everyone EmptySun Oct 03, 2010 9:45 pm
VATS issue may be unrelated to stalling/ rough idle problem, but deff. VATS problem. Sometimes several attempts to start before security light does not trigger and car starts. FSM on the way now. along with OBD II scanner will add mileage to sig asap.
PostSubject: Re: Hello Everyone   Hello Everyone EmptySun Oct 03, 2010 9:55 pm
Welcome. The Security issue will cause the car not to start, but will not cause a stall. That's another issue. Read/post in this thread for help with VATS/Pass Key II:
http://rivperformance.editboard.com/interior-f20/write-up-no-start-3-min-delay-disabling-pass-key-ii-security-t4564.htm
Welcome to the forum!
PostSubject: Re: Hello Everyone   Hello Everyone EmptyMon Oct 04, 2010 12:42 am
Welcome!!! I'm sure the info on this site will help you. smile
GreenJeanS
GreenJeanS
PostSubject: Re: Hello Everyone   Hello Everyone EmptyMon Oct 04, 2010 6:49 pm
Thanks AA, and everyone for the warm welcome. I have been reading that thread thoroughly. part of why i decided to sign up. I understand the stalling and VATS are unrelated. sorry I have given everyone the idea otherwise. VATS has been an issue for me for a while now. stalling is another much newer problem. Recommend any good threads for stalling?
PostSubject: Re: Hello Everyone   Hello Everyone EmptyMon Oct 04, 2010 10:36 pm
That depends. Does it start right back up? Is the SES light on?
Are there certain conditions present when it happens? or is the stalling totally random?
GreenJeanS
GreenJeanS
PostSubject: Re: Hello Everyone   Hello Everyone EmptyMon Oct 04, 2010 11:44 pm
Yes, so far starts back up, no SES light. would say happens while coming to stop at a light. either period of rough idle followed by stall, or just steady drop in rpm to stall. then restart and drive with little incident.(usually only once per trip, maybe 10 miles) **note** last stall resulted in very rough idle upon restart,
PostSubject: Re: Hello Everyone   Hello Everyone EmptyTue Oct 05, 2010 4:35 pm
Where's the pic's?
PostSubject: Re: Hello Everyone   Hello Everyone EmptyTue Oct 05, 2010 4:47 pm
In the Showroom, hopefully.
PostSubject: Re: Hello Everyone   Hello Everyone EmptyTue Oct 05, 2010 7:56 pm
No, there not!!! rolleyes
tracyk859
PostSubject: Re: Hello Everyone   Hello Everyone EmptySun Oct 24, 2010 11:03 pm
Hi, I am Tracy . I am a new member of forum. Would a newcomer be warmly welcome here? Good day you guys!!!
__________________
watch free movies online
Merit : 155
PostSubject: Re: Hello Everyone   Hello Everyone EmptyMon Oct 25, 2010 2:02 am
Sounds like ignition switch for the start/no start and rough idle is something else. It will take a while to sort it all out.
Ign switch not too $$ bad (you can keep the old *lock* and just replace the switch) if you DIY.
Hello Everyone
