Name : robotennis Age : 56 Location : las vegas Joined : 2007-12-17Post Count : 5560 Merit : 142
Subject: home alignment Sun Oct 03, 2010 6:43 pm
does anyone here do their own alignment? I've installed cam bolts on my steering knuckle so i can change camber without using a special tool.i also have a Longacre caster/camber gauge to fine tune.i plan on using the string method to measure toe. does anyone have a preferred method?
Name : Aaron Age : 40 Location : C-bus, Ohio Joined : 2007-01-13Post Count : 18327 Merit : 240
Subject: Re: home alignment Sun Oct 03, 2010 7:28 pm
Measuring wheel front/rear for toe works. It's easier using a pair of aluminum plates, either homemade or buy something like this:
'05 GTO • 85k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26 Because fun
'70 Olds Ninety-Eight Holiday Coupe • 116k miles • 455 Rocket V8 Because cool
'95 Celica • 152k miles • 0-60: yes Because free
Subject: Re: home alignment Mon Oct 04, 2010 6:30 am
I am thinking of getting a pair of those too. I did my alignment last night. It came out pretty good using the string method,but i ididnt lock the steering wheel,so while the wheels are pinting straight ahead,the steering wheel is a little cockeyed.have to redo today......
