Straighteight Member
Age : 89 Joined : 2007-01-22 Post Count : 66 Merit : 1
| Subject: 98 Transmission oil pan gasket Thu Oct 14, 2010 7:16 am | |
| There seems to be two different gaskets available for the 98 tranny. Any way to tell in advance which is which, and why the difference? | |
Ash Enthusiast
Name : Marty Age : 46 Location : S. Central Indiana Joined : 2008-05-21 Post Count : 115 Merit : 4
| Subject: Re: 98 Transmission oil pan gasket Thu Oct 14, 2010 9:20 am | |
| The only difference that I know of is the pan capscrew diameter/size. 8mm or 6mm. I would pull one of the capscrews out and measure the shank, then go from there.
I thought it was '99+ 4T65E-HD transmissions only. I know mine is the 6mm shank capscrews. I may be wrong on the years though.
Hope this helps.
Cheers | |
| Subject: Re: 98 Transmission oil pan gasket Thu Oct 14, 2010 1:22 pm | |
| - Straighteight wrote:
- There seems to be two different gaskets available for the 98 tranny. Any way to tell in advance which is which, and why the difference?
Can I ask where are you looking that has 2 different possible gasket P/N's for the Trans Pan. There was only one trans offered and in my searching I have found only one GM P/N for the gasket. In the aftermarket world there will be 2 gaskets, but, that is only because one is a paper type and the other more closely matches the OEM which is made up of a metal sheet for a core and has rubber bonded to both sides. The OEM or OEM replacement is a re-usable gasket and is much better at sealing leaks. I found the good OEM type available at NAPA, although you must be specific when asking for a gasket because they also sell a paper type (cheaper). There computer does have remarks in it that mentions the more expensive gasket is metal with bonded rubber. HTH, Rick | |
| Subject: Re: 98 Transmission oil pan gasket Thu Oct 14, 2010 2:41 pm | |
| Buick dealer told me there were two and he only had one of the two. Soooo of course I tried to diferentiate to determine which one I needed before tearing the old one apart. | |
| Subject: Re: 98 Transmission oil pan gasket | |
