 Porting M90 the third generation
Orakool
PostSubject: Porting M90 the third generation   Wed Nov 03, 2010 5:23 am
Greetings from Russia!
Russia has lagged behind in the world tuneng compressors and consequently I will be very grateful to YOU if YOU write as correctly to do porting eaton m90 the third generation. If you will be not not complicated by those lay out a photo of all operations.
As there is a question that it is necessary to make to raise target air pressure eaton m90 the third generation to 1,2-1,5bar
Thankful in advance!!!!!
