 corsa exhaust
Merit : 64
PostSubject: corsa exhaust   Thu Nov 25, 2010 8:58 pm
I just bought a "new" 14150 Corsa exhaust built for the 99-04 Seville on craigslist. 2.5" mandrel bent T304 SS.
The workmanship seems top notch. I'll eventually get around to installing it and will report back.
PostSubject: Re: corsa exhaust   Thu Nov 25, 2010 9:02 pm
we would all like to hear that too
PostSubject: Re: corsa exhaust   Thu Nov 25, 2010 10:13 pm
Jason wrote:
I just bought a "new" 14150 Corsa exhaust built for the 99-04 Seville. 2.5" mandrel bent T304 SS.
First: I would very much like to hear it when you get around to installing it.
Second: You just can't help yourself, can you. Must keep on modding.
Which car is this going on, I'm getting confused, as of late.
Rick
Merit : 64
PostSubject: Re: corsa exhaust   Fri Nov 26, 2010 4:29 pm
Sort of. I've always wanted to find out if the STS exhaust fit the g-body Riviera. I think I'll be installing it on the modded riviera (green). Since both Rivieras are going to be used in the winter, the exhaust needs to be stainless.
Merit : 64
PostSubject: preliminary examination   Fri Nov 26, 2010 4:52 pm
I took a few photos of the components of the Corsa kit. Here they are:
The pipe is 2.5" x 0.065" 304SS.
The 3" cat-delete pipe and reducer are not part of the Corsa kit but of the SSautochrome header kit. I'll probably need to use at least the 3" section of pipe.
The split is 2.5" into 2x 2.5". The split is much smoother than the stock one which is almost 90 deg and is 2.25" into 2x 1.875". The welds are above reproach. The Corsa kit comes with wall required hardware: high-quality 304SS torca clamps. The hangers are also 304SS.
The "resonator" is 2.5" ID and has an 18" long case. The 2 mufflers are side-specific and have 16" long cases. The curve in the mufflers' neck will go a long way for proper tip placement.
Dual rear exit with fully polished 304SS 2x 3.5" Tips. I like them.
The mufflers and resonator are different than most others. The inside is solid, with only a few holes. There are no baffles and there's no packing. I immediately wanted to cut one open to see what the inside of one looked like, so I looked it up. Corsa calls it "reflective sound cancellation" which is their fancy name for Helmholtz resonance. It's tuned for the N*, so I am really looking forward to hearing what it sounds like on the L67.
their PA spin on it:
PostSubject: Re: corsa exhaust   Fri Nov 26, 2010 5:05 pm
nice! i just looked up the price for this lovely bit of kit. wow! you must love your riv!
Merit : 124
PostSubject: Re: corsa exhaust   Fri Nov 26, 2010 8:50 pm
very cool! can't wait to hear it
VJD2
PostSubject: Re: corsa exhaust   Mon Nov 29, 2010 1:29 am
*Subscribed*
PostSubject: Re: corsa exhaust   Mon Nov 29, 2010 7:04 pm
Looks awesome. I wouldn't change a thing about that exhaust. Love those tips. I'm jealous. As said, I'm looking forward to hearing what it sounds like. smile
VJD2
PostSubject: Re: corsa exhaust   Wed Dec 15, 2010 12:55 am
Any updates?
Merit : 64
PostSubject: Re: corsa exhaust   Tue Dec 21, 2010 5:20 pm
no, I probably won`t get to working on it until the spring.
VJD2
PostSubject: Re: corsa exhaust   Thu Dec 23, 2010 10:36 am
Sounds good. Keep us updated!
Thanks and happy holidays!
Merit : 64
PostSubject: Re: corsa exhaust   Tue Jan 18, 2011 2:32 pm
I just got a second "gently used" corsa cat-back. No need to decide which car to put it on now. Also, I'll be able to assess the sound on an otherwise stock riv happy
Merit : 64
PostSubject: Re: corsa exhaust   Fri Feb 04, 2011 1:36 pm
I got the starter changed today. Although I hate to get something so simple done at the garage, it's been way too cold to do it in the driveway. I brought some of the pipes of the corsa and did a mockup while it was on the lift. It looks like it's going to be an easy install.
The 2 main areas of concern are
1) Mating the 3" dp to the 2.5'' exhaust, which will require a 3-2.5" SS reducer. I can probably use an additional 3" clamp, but I'd rather get it welded
2) I'm not sure if the tips will contact the lower gray valance.
Merit : 124
PostSubject: Re: corsa exhaust   Thu May 05, 2011 8:51 pm
Hey Jason, It's spring now!
PostSubject: Re: corsa exhaust   Fri May 06, 2011 9:03 pm
Its spring, even in Canada.
Merit : 122
PostSubject: Re: corsa exhaust   Fri May 06, 2011 11:41 pm
... I dunno... we had snow 2 weeks ago ...
Merit : 64
PostSubject: Re: corsa exhaust   Sat May 07, 2011 9:58 am
Karma is right. I need to pick up a 3" to 2.5" 304SS reducer and I'll be good to go. I finally found a place that could make one.
Merit : 64
PostSubject: Re: corsa exhaust   Sat Feb 04, 2012 8:47 pm
I sold the brand new one and kept the used one.
I'm picking up this one in Cleveland, so don't buy it out from under me.
Merit : 124
PostSubject: Re: corsa exhaust   Sun Feb 05, 2012 2:18 am
Merit : 64
PostSubject: Re: corsa exhaust   Sun May 06, 2012 1:00 am
I guess I should take some pics of the install... If I make a vid, where can I post it aside from youtube ?
Merit : 124
PostSubject: Re: corsa exhaust   Sun May 06, 2012 10:27 pm
Photobucket
Merit : 64
PostSubject: Re: corsa exhaust   Wed May 16, 2012 11:10 am
Well the exhaust is installed. It fits with just a bit of tweaking. I like the look and material (304SS). The craftsmanship of this system is top-notch. The sound can best be described as "unrefined". Definitely not what you would expect a Riviera to sound like! It's tuned for a different engine and it shows. Corsa tuned it for the Northstar, so it's eliminating the unwanted frequencies that engine would be producing, but not some that the 3800 is prone to making. It's a bit weird because it's extremely quiet at cruise, with no drone at any of the RPM, which I like. Outside the car, I find it's quite loud at idle, especially right behind the car. I've never seen an exhaust that is so noticeably loud depending on where you are standing. The exhaust has somewhat of a "bark" or snarl and it screams at WOT. Personally I think the 3800 just doesn't sound that good to begin with so I think this is as good as it's going to get. I like it. I'm toying with the idea of welding in the old Magnaflow 3" "resonator" in front of the resonator on this one to see if it will tame the sound just a bit. It doesn't really need it, but I have the resonator so it will be free. I definitely prefer it to my old 3" single exhaust.
Here are some pics. I don't really mind if my plate is showing because I will be changing them soon.
Here are a few videos
1) Cold startup and idle. Didn't warm up enough to drop idle down to 700. Stayed at 1k. http://video.cardomain.com/VideoPlayer.aspx?id=2385595
2) Driving around, windows and sunroof closed: http://video.cardomain.com/VideoPlayer.aspx?id=2385594
3) Driving with sunroof cracked open. Acceleration. http://video.cardomain.com/VideoPlayer.aspx?id=2385592
Merit : 122
PostSubject: Re: corsa exhaust   Wed May 16, 2012 11:39 am
Finally installed eh?
Looks nice!
Do you normally do car work in your flight suit?
Merit : 64
PostSubject: Re: corsa exhaust   Thu May 17, 2012 10:26 am
no I took the vid before going to work.
corsa exhaust
