| 1997 Buick Riviera Hood Release | |
+41998 Riv albertj Abaddon Riv097 8 posters |
Riv097 Special
Name : Al Carr Joined : 2010-12-18 Post Count : 2 Merit : 0
| Subject: 1997 Buick Riviera Hood Release Sat Dec 18, 2010 4:21 pm | |
| Can any one tell me how to open the hood when the release will not work? | |
| Subject: Re: 1997 Buick Riviera Hood Release Sat Dec 18, 2010 6:21 pm | |
| Well, if the cable is broken at the latch itself, good luck. You'll need to take off the splash shield under the front end in order to gain an opening to reach up and through. If you can reach it, use a screw driver or a pry-bar to release the hood.
Not sure how to do it on a Riv (never had to), but I assume the above method is the only way. | |
| Subject: Re: 1997 Buick Riviera Hood Release Sat Dec 18, 2010 7:59 pm | |
| - Abaddon wrote:
- Well, if the cable is broken at the latch itself, good luck. You'll need to take off the splash shield under the front end in order to gain an opening to reach up and through. If you can reach it, use a screw driver or a pry-bar to release the hood.
Not sure how to do it on a Riv (never had to), but I assume the above method is the only way. If you lay on the ground and look up at the hood latch it will be obvious how to open it w/o using the remote cable. | |
| Subject: Re: 1997 Buick Riviera Hood Release Sat Dec 18, 2010 8:55 pm | |
| It's also possible that it is simply sticking a bit. Try having someone pry up slightly on the hood while you pull the release. Mine requires this from time to time, esp in winter. It pops right up with a little pull up. | |
| Subject: Re: 1997 Buick Riviera Hood Release Sat Dec 18, 2010 9:33 pm | |
| - 1998 Riv wrote:
- It's also possible that it is simply sticking a bit. Try having someone pry up slightly on the hood while you pull the release. Mine requires this from time to time, esp in winter. It pops right up with a little pull up.
Conversely, the hood bumpers might be set too tight, so also try having someone push down on the front of the hood while you pull the handle... | |
| Subject: Re: 1997 Buick Riviera Hood Release Sat Dec 18, 2010 9:35 pm | |
| - albertj wrote:
- If you lay on the ground and look up at the hood latch it will be obvious how to open it w/o using the remote cable.
So much for security... at least they can't steal the battery. | |
whit2285 Enthusiast
Name : Mike Age : 49 Location : Illinois Joined : 2007-12-20 Post Count : 127 Merit : 3
| Subject: Re: 1997 Buick Riviera Hood Release Sat Dec 18, 2010 10:40 pm | |
| when i bought my car the latch was rusted, and seized . i had to take the grill out, then i was able to unbolt the latch assembly. soaked it with pb blaster cleaned it up , then reinstalled. its has work ever since then.. not to difficult of a proses.... | |
Jamax Enthusiast
Name : Jim Fleck Location : Crystal River, FL Joined : 2010-06-24 Post Count : 143 Merit : 8
| Subject: Re: 1997 Buick Riviera Hood Release Sat Dec 18, 2010 10:48 pm | |
| Just as a reminder: On the seventh day He rested. And on the eighth day, looking down and seeing that all was not quite right with the world, God gave us WD-40. | |
| Subject: Re: 1997 Buick Riviera Hood Release Sat Dec 18, 2010 11:34 pm | |
| - Jamax wrote:
- On the seventh day He rested.
And on the eighth day, looking down and seeing that all was not quite right with the world, God gave us WD-40. "God forbid" he just went back to day 5 and un-invented corrosion... | |
99Rivman Aficionado
| Subject: Re: 1997 Buick Riviera Hood Release Sun Dec 19, 2010 8:03 pm | |
| Subject: Re: 1997 Buick Riviera Hood Release Sun Dec 19, 2010 9:23 pm | |
| - 99Rivman wrote:
- I wasn’t sure so I wanted to check, nothing has to be removed to open the hood from the outside. I just tried it on one of mine and there is nothing to it. If you reach up between the bumper brace and the air deflector, follow the latch mount up, and then feel the aft side of the latch for where the cable is attached, you can push the release by hand.
I did not wanna say the above in so many words... but yeah. If you lay on the ground and look up at the hood latch it will be obvious how to open it w/o using the remote cable. For you weight reduction freaks: If you felt like it you could tackweld or braze a little paddle on that sucker and get rid of the interior release. Since the cat's out of the bag, I will add that this approach (lay on the ground and look up at the hood latch) works for more cars than I care to list, and that after you open a few you don't need to look first anymore... ...be sure to use your new powers for good, and you will keep them. (Conversely, you will be lost...) And by the way it helps if you wear gloves because sometimes the factory leaves sharp edges on the mechanism. Albertj | |
whit2285 Enthusiast
| Subject: Re: 1997 Buick Riviera Hood Release Sun Dec 19, 2010 11:15 pm | |
| that's if there's no corrosion preventing it from opening, if its corded you have to take of the grill.. | |
| Subject: Re: 1997 Buick Riviera Hood Release Mon Dec 20, 2010 9:05 am | |
| - whit2285 wrote:
- that's if there's no corrosion preventing it from opening, if its corded you have to take of the grill..
This is where a pry-bar comes in handy | |
| Subject: Re: 1997 Buick Riviera Hood Release | |
