| Vibration at idle (only when in gear) | |
+5deekster_caddy LARRY70GS albertj AA VegasScott 9 posters |
VegasScott Enthusiast
Name : Scott Location : Las Vegas, Nevada Joined : 2010-12-21 Post Count : 117 Merit : 8
| Subject: Vibration at idle (only when in gear) Tue Jan 04, 2011 2:19 pm | |
| I've got my car purring nicely at idle when in park or neutral, but I noticed when I'm at a traffic light or somewhere when I'm in gear and idling, I notice a bit more vibration. I'm hoping to do a transmission fluid and filter replacemnt this weekend if it isn't so friggin' cold! That may help my problem some, but just want to see if there are any other issues I should be on the look out for.
Thanks! VegasScott | |
| Subject: Re: Vibration at idle (only when in gear) Tue Jan 04, 2011 3:36 pm | |
| Could be a bad engine mount, or loose interior panels, depending on what you hear. Or it could be a vibrating heat shield near the catalytic converter. You can try bending the shield slightly, and the noise might go away. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
| Subject: Re: Vibration at idle (only when in gear) Tue Jan 04, 2011 4:59 pm | |
| It's not so much a sound that I'm hearing... It's more of a vibration I'm feeling... I'll have to check out the factory service manual when I get home tonight.
VegasScott | |
| Subject: Re: Vibration at idle (only when in gear) Tue Jan 04, 2011 5:16 pm | |
| - VegasScott wrote:
- I've got my car purring nicely at idle when in park or neutral, but I noticed when I'm at a traffic light or somewhere when I'm in gear and idling, I notice a bit more vibration. I'm hoping to do a transmission fluid and filter replacemnt this weekend if it isn't so friggin' cold! That may help my problem some, but just want to see if there are any other issues I should be on the look out for.
Thanks! VegasScott Most likely weakening engine mounts. Over the history of the 3800 engine, its inherent imbalance is probably legend among the (mostly now retired) engineers that had a hand in it. This is why it has a balance shaft and that beefy harmonic balancer (and if you get the factory balancer you get a high tech polymer insert, not just neoprene). Over the years many things were done to try to smooth it out. Look it up on Wikipedia and you'll see some of that history. The Series I was, I understand, the most improved of the series--later ones were better but not to the degree that the SI was improved over its predecessor. But it still vibrates so much, you gotta wonder who's putting the quarters in (think about the coin operated vibrating chairs you see at amusement places...) and make 'em stop. So the soft mounts on the Riviera were the way chosen to use up the energy of the inherent vibration of the engine; they probably did not cost all that much compared to what they did (when new) and frankly they are not very robust. When you crawl under the car to have a look at them please try to restrain your laughter. The beefiest mount, actually, is the one at front of engine by the belts and accessories (alternator etc). The rest are little "+" shaped inserts in various castings. They are very compliant given the torque and horsepower of the engine. IMHO all you have to do to wack out a mount is a couple months straight of 'jackrabbit' starts from a dead stop. What to do about this?!? Well - Len Rapkins wrote the inserts are now available. Cheaper than the whole mounts by a long shot ($$ instead of $$$) When I get around to replacing mine (again) I think I will fill the voids with low-durometer 3M WindowWeld to soak up the energy without allowing the fatigue caused by the compliance and excursion of the stock mounts. Also elsewhere on this site is a write up about casting your own. Albertj | |
| Subject: Re: Vibration at idle (only when in gear) Tue Jan 04, 2011 5:24 pm | |
| Okay, I understand that the engine may have an inbalance, but there is NO vibration at idle when the car is in P or N. It is only after it is engaged in D do I feel the vibration. As soon as I'm off idle, it's butter smooth again.
Any other ideas?
| Subject: Re: Vibration at idle (only when in gear) Tue Jan 04, 2011 5:41 pm | |
| Our Rivieras idle at a low RPM in gear. I notice some vibration in my Riv sitting at a light. It doesn't bother me at all. Not sure how severe yours is. _________________ 98 Riviera SC3800 All stock except gutted air box. 1970 Buick GS455 Stage1, TSP built 470BBB, 602HP/589TQ Best MPH, 116.06 MPH, Best ET, 11.54 https://www.youtube.com/watch?v=UHCda-t_Jls https://www.youtube.com/watch?v=sfT2tEO4XcU
| Subject: Re: Vibration at idle (only when in gear) Tue Jan 04, 2011 5:45 pm | |
| - VegasScott wrote:
- Okay, I understand that the engine may have an inbalance, but there is NO vibration at idle when the car is in P or N. It is only after it is engaged in D do I feel the vibration. As soon as I'm off idle, it's butter smooth again.
Any other ideas?
Thanks! VegasScott No other ideas, just a further explanation. The reason the vibration quits in neutral is the engine torque isn't working against a stalling torque converter and the harmonic balancer and balance shaft are adequate to damp the remaining harmonic vibration. At idle, in Drive, as your mounts weaken they are not adequate to damp the vibration of the engine working against the stalled converter. You basically feel every pop. 650 rpm at 6 pops per rev gives you a buzz around 3800 hz and what you are feeling is the lower harmonic of that in time with the unbalanced firing order of the engine. Get it? When the car is new all the damping works. But the mounts are so weak that when they wear a littl bit you really feel it fairly strongly. The car will be drivable for a long time before the mounts are so wack they are causing other problems. But that's not what you asked... Try this at your own risk if you're feeling lucky and curious (just remember that curiosity killed the cat and satisfaction brought it back): Park the car and chock the wheels. Open the hood, start it and watch the engine. rev it a little bit, see what it does. With your parking brake set, step on the service brake (firmly) and put the car in gear while you watch the engine. The engine will rock, call the distance of the rocking the excursion. While still holding the brake flutter the accelerator a little. A couple hundred RPM will make that engine look like it's coming out to get you (or anything else within 10 feet) because your mounts are weakened, which I bet they are. you will get well more than an inch or 2 excursion. New mounts don't let the engine have much excursion under those conditions, thinking about when I last replaced mine I'd say an inch or so. Worn mounts allow much more excursion with a little throttle flutter, you'll have *no problem* seeing the engine dance about. You can get the new mounts to let the engine to move a lot too but you have to take the revs way up. When they are worn a little flutter couple hundred RPM will do it. And dont do this a whole lot, it will fairly quickly overheat the torque converter. 15-30 seconds should prove the point. Albertj | |
| Subject: Re: Vibration at idle (only when in gear) Wed Jan 05, 2011 9:42 pm | |
| Is the vibration steady, or more of an occasional popping? If occasional I would suspect injectors. I replaced my injectors with a cleaned (flow tested) set and was SHOCKED at the difference and how much it smoothed out. | |
| Subject: Re: Vibration at idle (only when in gear) Wed Jan 05, 2011 10:07 pm | |
| Hey Derek!
I don't think it's the injectors, because the car has good power, pulls nicely, and idles great! The only time I feel that vibration is when it's idling and in gear, like at a stoplight, or stop sign. As soon as you get even 100RPM above idle, it's smooth as butter again.
When I replaced the intake manifold gaskets, I cleaned the injectors even though they looked pretty good to start with and replaced their O-rings.
Are there any vaccum lines I should check?
Thanks Guys!
VegasScott | |
| Subject: Re: Vibration at idle (only when in gear) Wed Jan 05, 2011 11:36 pm | |
| As you can see Scott, a given problem can produce as many ideas as we have people on the board. However, any engine will have more vibration when in gear than when in Park... It's idling at its slowest RPM, which is the most challenging condition for smooth firing, and being coupled to the transmission transfers the vibrations to the passenger compartment more clearly. While the motor mounts ARE expensive, and bad mounts will also transmit more vibration to the body, I don't think Series II Buicks have any more external vibration than any other engine. Thanks to the improvements that Albert listed, as well as the first and most important change, the even-firing split-pin crankshaft, you can lay your hand on the engine in Park and feel how smooth it is... Unlike the pre-1977 "odd-firing" engines, these don't need the "rubber band" motor mounts that those early engines had. I remember an early-70's 231 in a GM compact wagon that would bounce all around the engine compartment when idling - in Park! What surprises me, this being an idle problem, is that no one has suggested checking/cleaning the Idle Air Control and the Mass Airflow Sensor... I could occasionally feel my idle when at a stop light, and a gentle spray of electronics cleaner on the MAF sensor cured it - the big headache was those damned Security-Torx screws! And yes - you should check all the vacuum fittings and hoses... They're sneaky, and they are reaching the age of "crystallization". | |
| Subject: Re: Vibration at idle (only when in gear) Thu Jan 06, 2011 11:12 am | |
| - Eldo wrote:
- As you can see Scott, a given problem can produce as many ideas as we have people on the board.
And yes - you should check all the vacuum fittings and hoses... They're sneaky, and they are reaching the age of "crystallization". great points. Now, if you just need something to do -- when the car is idling in neutral (park) look at the tach. If it is fluttering at all, or hunting about (revs move a bit higher/lower) it is time to pull and clean the throttle body (not just the wipe-it-out-with-a-rag thing). When things are all OK the idle does not hunt. Albertj | |
| Subject: Re: Vibration at idle (only when in gear) Thu Jan 06, 2011 2:30 pm | |
| Thanks for the additional suggestions guys, but...
That's just the thing... There is no idle problem to speak of. The engine runs GREAT! I'm just trying to figure out why there's so much more vibration when in gear and idling stopped versus out of gear and idling sitting.
I like a car that at idle (whether in gear or not) will run so smoothly that you start to question whether or not the car is on. You answer that question by slightly depressing the accelerator and then hear or feel the engine.
That's the goal of this thread. Uncovering what it takes to achieve what I described above.
Thanks for the help and keep the suggestions coming. I'll report back after this weekend when I finish the rest of the PM work I want to complete on the car.
Thanks guys!
VegasScott | |
| Subject: Re: Vibration at idle (only when in gear) Thu Jan 06, 2011 2:34 pm | |
| if you are having no idle problem then vibration in gear is weak mounts...
| Subject: Re: Vibration at idle (only when in gear) Thu Jan 06, 2011 3:31 pm | |
| - Quote :
- There is no idle problem to speak of. The engine runs GREAT! I'm just trying to figure out why there's so much more vibration when in gear and idling stopped versus out of gear and idling sitting.
Not the solution to your problem, but it helps to understand that vibrations are basically resonances, or when materials get excited by very specific frequencies of mechanical energy. A material's molecular structure, mass (weight), and security of mounting/insulation all play a role in how much vibration is transferred from the engine, through these materials, and on to you the driver. Idle RPM fluctuates depending on engine temperature, anywhere from 1000 or more on a cold morning down to 630 for a warming engine. For this reason, you may notice the vibration is more prominent at certain temperatures than others. At 630 RPM, the engine is emanating a frequency of about 10.5Hz into the car. At 750 RPM, the resonance is closer to 12 Hz. This may seem like a small difference, but at subsonic frequencies such as these, a range of 6 Hz makes up an entire octave. A tiny shift in material weight, mounting/insulation, or engine RPM can really make a difference. This is why we have mass-adding materials in the floor & firewall - to increase mass, which lowers their resonant frequencies to values that to not become excited. This is also why we have rubber engine mounts - as insulation to absorb mechanical energy and change it to heat. There is a third option - to change idle RPM. You will notice in gear, with your foot on the brake, if you slightly push the gas the vibration may attenuate or even disappear. This is also why the vibrations go away in neutral, as RPM increases.I had the same problem as you, probably a combination of loosely mounted materials and degraded insulation materials (engine mounts, etc.). These are common things in aging cars. I isolated one vibration to the heat shield under the car. Bending this slightly created tension, or more secure mounting, which quieted the sound. I also tried adding insulators to identified interior objects. Poster putty works behind speaker grills, and a very small o-ring helped the rear-mirror buttons. But in the end, there were just to many noises to hunt down. My ultimate solution was to increase the idle RPM in gear 50-100 higher than stock using PCM tuning software, which caused the resonances to stop, and perceived vibrations to cease. Some would call it a band-aid fix, but I found it well worth doing for the result. _________________ '05 GTO 6.0L • 6-spd • 95k miles • 0-60: 4.8s • 16.9 avg MPG • Nelson Ledges Lap: 1:26'95 Celica GT 2.2L • 5-spd • 165k miles • 0-60: yes'98 SC Riviera • 281k miles • 298 HP/370 TQ • 0-60: 5.79s • ET: 13.97 @ 99.28 • 4087 lb • 20.1 avg MPG • Nelson Ledges Lap: 1:30 3.4" pulley • AL104 plugs • 180º t-stat • FWI w/K&N • 1.9:1 rockers • OR pushrods • LS6 valve springs • SLP headers • ZZP fuel rails KYB GR2 struts • MaxAir shocks • Addco sway bars • UMI bushings • GM STB • Enkei 18" EV5s w/ Dunlop DZ101s • F-body calipers EBC bluestuff/Hawk HP plus • SS lines • Brembo slotted discs • DHP tuned • Aeroforce • Hidden Hitch^^^ SOLD ^^^ '70 Ninety-Eight Holiday Coupe 455cid • 116k miles^^^ SOLD ^^^ | |
Jason Aficionado
| Subject: Re: Vibration at idle (only when in gear) Thu Jan 06, 2011 4:34 pm | |
| Mel's white riv has the same slight vibration at idle in gear and the car only has 26k miles. It's been doing it since she's owned it at 18k mi. The vibration -which is definitely not a rattling- can be felt mostly through the steering wheel. Like Aaron mentioned, it's only at about 650 rpm. I was simply going to do a motorvac treatment this spring and then raise the idle by a 50 or so rpm if that didn't do it. It had never occurred to me it might be caused by weakened mounts with such low mileage. | |
| Subject: Re: Vibration at idle (only when in gear) Thu Jan 06, 2011 4:49 pm | |
| - Jason wrote:
- Mel's white riv has the same slight vibration at idle in gear and the car only has 26k miles. It's been doing it since she's owned it at 18k mi. The vibration -which is definitely not a rattling- can be felt mostly through the steering wheel. Like Aaron mentioned, it's only at about 650 rpm. I was simply going to do a motorvac treatment this spring and then raise the idle by a 50 or so rpm if that didn't do it. It had never occurred to me it might be caused by weakened mounts with such low mileage.
After looking at my mounts when I replaced them, I don't think it's mileage, I think it's some combination of age/hours of use/higher torque whacking from the SC engine. Don't need mileage if the rubber's deteriorating from heat/weather/whatever. I am also pretty sure that if it was not the lowest bidder got the deal for those inserts, it was a low one. When I replaced mine they were badly checked, looked like weather checking as you'd see on an old(er) tire. I am also pretty sure they used same mounts for the NA and SC versions of the engine. They would die faster on the SC engine from stretching, the SC engine accelerates a little harder (heh heh). I also suspect there's reasons they did not use fluid-filled mounts. Lots of cars use Bosch fluid-filled puck mounts. They work well. Thing with them, though, is they start to leak after a time and that's what kills them. Oh, well. The mounts as designed work. However, based on what I've seen I suspect they don't work very long. Albertj | |
| Subject: Re: Vibration at idle (only when in gear) Thu Jan 06, 2011 6:18 pm | |
| If I had to guess, I'd suspect that Albert was right when he mentioned the mounts back on the first page of this thread. I'll be sure to check them out this weekend when I jump in on all the rest of the maintenance I want to complete.
VegasScott | |
| Subject: Re: Vibration at idle (only when in gear) Sat Jan 08, 2011 4:30 pm | |
| Great news! I'm presently in the process of trying to replace my belts and I think I located the cause of this vibration I'm talking about. The motor mount I need to remove was not all that tight between the mount and the bracket, AND (here's where it gets good)...
The 2 lower bolts for the bracket were sticking out of the car 1/8 to 1/4 inch!!! They were barely even finger tight!
The rubber portion of the mount was in decent shape. It wasn't all dry rotted and beat up. So I'm hoping when I get this thing all back together at the end of the day my vibration is gone!
VegasScott | |
| Subject: Re: Vibration at idle (only when in gear) Sat Jan 08, 2011 6:53 pm | |
| - VegasScott wrote:
- Great news! I'm presently in the process of trying to replace my belts and I think I located the cause of this vibration I'm talking about. The motor mount I need to remove was not all that tight between the mount and the bracket, AND (here's where it gets good)...
VegasScott Consider cleaning those bolts/the nuts in chassis off with dry gas and then using Loctite Blue (the removable kind) on the bolts. And if they backed out due to being oil soaked you might want to find that leak. Albertj | |
| Subject: Re: Vibration at idle (only when in gear) Sun Jan 09, 2011 12:12 pm | |
| - albertj wrote:
- Consider cleaning those bolts/the nuts in chassis off with dry gas and then using Loctite Blue (the removable kind) on the bolts.
No oil. And if there was, due to the height in the body, you'd have yourself one nasty cylinder head leak! Thank God it's not that serious! Here' my theory... From reading here on this, new favorite forum of mine, I saw several members complain that when their pulleys let loose or a threw a belt, that they also caused some damage to the under cover insulation on the hood. I saw that my car also has this damage. My accessory belt looked pretty good, but my supercharger belt showed a lot of age. I'm thinking one of the previous owners fixed the bare minumum on the car when they saw the intake manifold gaskets leaking and being told what theyd have to pay to fix those as well by a shop. The guy probably figured, "Ah screw it. It's an old car, just fix the belt so I can drive it and I'll sell it." The mechinic was probably a rookie at an independent shop, and wasn't familiar with the repair. He tightened up the top motor mount bolts, probably took a smoke break, or a lunch break and then came back to the car thinking he was done. Needless to say, I fixed it. It's got my blue thread lock on those threads. I'm so VERY HAPPY with the results! No more vibration! VegasScott | |
| Subject: Re: Vibration at idle (only when in gear) Sat Jan 29, 2011 1:33 pm | |
| 2 week update.... As Lee Corso says, "Not so fast my friend!" (If you have to ask who he is, you're obviously not a college football fan! ) I can't believe nobody suggested checking the supercharger couple! My car runs great, but I still have a bit of a vibration, rumble at idle only when in gear. Upon reading the supercharger threads here and on other forums, it sounds like my issue would be solved by replacing the supercharger couple. So, again I yield to y'alls prior experiences. Who should I order the coupler from? I've seen the green colored ones on ebay that come with the GM specific oil. Are there any other vendors I should consider? Thanks! VegasScott | |
| Subject: Re: Vibration at idle (only when in gear) Sat Jan 29, 2011 1:46 pm | |
| A bad coupler wont cause any vibration.It just rattles | |
| Subject: Re: Vibration at idle (only when in gear) Sat Jan 29, 2011 1:56 pm | |
| - VegasScott wrote:
- 2 week update.... As Lee Corso says, "Not so fast my friend!" (If you have to ask who he is, you're obviously not a college football fan! )
Thanks!
VegasScott The problems you posted did not suggest your coupler was bad or going bad. When they go they make a lotta noise but their mass is low so not much if any vibration. It's normal for a somewhat worn but good coupler to "chuckle" a little when cold, what that actually is is not the coupler but so to speak gear/linkage lash in the snout. That said, I got my replacement coupler and bearings from http://www.darossillc.com - my coupler "chuckled" for a long time but kind of all of a sudden started sounded like dueling Japanese hibachi chefs whacking utensils on their griddles. A BIG racket. That's when I replaced it. Albertj | |
| Subject: Re: Vibration at idle (only when in gear) Sat Jan 29, 2011 3:15 pm | |
| I also recomend getting your injectors cleaned.fouled injectors can chug a car to death.
@ AlbertJ: "a good coupler to chuckle" LOL I guess they do chuckle! | |
| Subject: Re: Vibration at idle (only when in gear) Sat Jan 29, 2011 3:31 pm | |
| - robotennis61 wrote:
- I also recomend getting your injectors cleaned.fouled injectors can chug a car to death.
@ AlbertJ: "a good coupler to chuckle" LOL I guess they do chuckle! Yeah they chuckle while waiting for the next ricer... | |
| Subject: Re: Vibration at idle (only when in gear) | |
