timbosmith Special
Name : Tim Smith Location : Decatur AL Joined : 2010-12-23 Post Count : 2 Merit : 0
| Subject: Turn signal timing relay location 96S/C Thu Nov 24, 2011 7:43 pm | |
| Need some quick help.......... Rather than go blindly into the under dash, can someone tell me a quick/easy way to find this jewel. It's VERY eratic and sometimes fails to flash the turn signals in either direction. Thanks | |
| Subject: Re: Turn signal timing relay location 96S/C Thu Nov 24, 2011 7:54 pm | |
| I say dive in man! just dive in blindly | |
| Subject: Re: Turn signal timing relay location 96S/C Fri Nov 25, 2011 12:36 am | |
| - timbosmith wrote:
- Need some quick help..........
Rather than go blindly into the under dash, can someone tell me a quick/easy way to find this jewel. It's VERY erratic and sometimes fails to flash the turn signals in either direction. Thanks After removing the lower dash trim panel (a few screws just under the lower dash, beneath the instrument panel) look up (you may need flashlight) and you will see a flasher for the turn signals and another for the emergency flashers. You may want to turn on the emergency flashers - they will click and the noise will make the "can" easier to find. The flasher relay should be held in a little metal clip on the steering column support. They are $8 to $16 each at an auto parts store **or** at a GM dealer. | |
timbosmith Special
| Subject: Re: Turn signal timing relay location 96S/C Fri Nov 25, 2011 6:21 pm | |
| Thanks for the timly reply. Hoped it was as other GMs BUT have learned to be cautious.
| Subject: Re: Turn signal timing relay location 96S/C Sun Nov 27, 2011 5:56 pm | |
| - timbosmith wrote:
- Thanks for the timly reply. Hoped it was as other GMs BUT have learned to be cautious.
The later GMs use electronic flashers or integrate the flasher into the body control computer. The last-gen Riv still used the thermal relay can. It can be replaced with a standard or HD electronic flasher. Or another thermal flasher. Cheap way out is to snag a few flashers (Buss 552) from a junkyard. | |
| Subject: Re: Turn signal timing relay location 96S/C | |
