 FAQ: Series II Supercharged V-6 Engine
Go to page : Previous  1, 2
josh97riv
PostSubject: Re: FAQ: Series II Supercharged V-6 Engine   Fri Mar 28, 2014 5:06 pm
Is it possible to use the n/a engine with the higher compression in a sc riv?
PostSubject: Re: FAQ: Series II Supercharged V-6 Engine   Fri Mar 28, 2014 8:04 pm
It is possible, but you have to know what you're doing and how to tune it correctly. We've had one SC Riv engine go "boom" running an L36 block.
More modern engines use direct fuel injection, which allows boost + high compression more easily. But it can be done with the SC 3800, just can't run as much boost.
josh97riv
PostSubject: Re: FAQ: Series II Supercharged V-6 Engine   Fri Mar 28, 2014 10:10 pm
Thanks,do you know if it mad about the same or more power with the L36?
PostSubject: Re: FAQ: Series II Supercharged V-6 Engine   Sun Mar 30, 2014 2:06 pm
I think there is more potential HP on tap because the higher compression requires less boost, keeping the supercharger spinning in a more efficient (lower) RPM range. You can build a normal L67 to be just as powerful, using more boost and hotter timing.
PostSubject: Re: FAQ: Series II Supercharged V-6 Engine   Mon Mar 31, 2014 7:43 pm
Doesnt Codith have the lower L26? Not sure if that's higher compression but it's the N/A engine, right?
PostSubject: Re: FAQ: Series II Supercharged V-6 Engine   Mon Mar 31, 2014 7:54 pm
Yes, L27 is the Series I 3800 N/A, L36 is the Series II N/A. I'm not sure if there's a preference for mating ether block to the L67 heads, but they are different blocks. Maybe turtle can educate us on the pros and cons of each.
PostSubject: Re: FAQ: Series II Supercharged V-6 Engine   Wed Apr 23, 2014 9:28 pm
What is the max Hz value the stock L67 MAF sensor can detect?
