 Backwards bolt?
PostSubject: Backwards bolt?   Thu Jan 06, 2011 4:29 am
Where is the backwards bolt i keep hearing about when removing the motor?
PostSubject: Re: Backwards bolt?   Thu Jan 06, 2011 10:22 am
Only ones I can think of are the screws that hold on the idler & tensioner pulleys.
PostSubject: Re: Backwards bolt?   Sun Jan 09, 2011 10:05 am
The "Backwards Bolt" or "Bastard Bolt" as it's also known, is really not such a big deal. One of the bellhousing bolts faces the other way, threaded into the transmission through a hole in the block instead of the other way round. It's down by the long part of the transmission, the opposite side from the starter. It can easily be reached with the passenger side wheel and inner fender liner removed (which you should have off if you are pulling the motor anyhow). A couple of long extensions and an 18mm socket and out it comes. If you don't know it's there, it can be puzzling to figure out why the engine isn't freeing up. If you know it's there, it's not a big deal.
You can reach it from the top with a box wrench, but it's a little tough to break free. I recommend a bunch of extensions and a breaker bar from the pass. side wheel opening.
PostSubject: Re: Backwards bolt?   Sun Jan 09, 2011 3:44 pm
Well thank you wish I would have known this 3 months ago. Me and my dad spent 2 days in a junkyard trying to pull out a motor and then couldnt get it seperated from the transmisson. We spent like 4 hours trying to find a bolt me may have missed and then gave up. Dammit could have had a pretty damn good supercharged motor and would have been driving a fully maroon car instead of a half one. lol wow. Thanj youv though
PostSubject: Re: Backwards bolt?   Sun Jan 09, 2011 11:32 pm
lol wut?
Merit : 134
PostSubject: Re: Backwards bolt?   Sun Jan 09, 2011 11:34 pm
lol wut?
The mounting bolts for the idler and tensioner pullies on the L67 engine are reverse threaded. This is so that the normal turning direction of the pulley would tend to tighten the pulley mounting bolt.
PostSubject: Re: Backwards bolt?   Sun Jan 09, 2011 11:41 pm
albertj wrote:
lol wut?
I've never removed any pulleys before pulling a motor.. lol
PostSubject: Re: Backwards bolt?   Mon Jan 10, 2011 12:10 am
^^^ good thing - you might've twisted'em off lol
Jamax
PostSubject: Re: Backwards bolt?   Mon Jan 10, 2011 9:57 pm
This isn't terribly important, unless you're looking for a new bolt. They're called left-hand thread bolts. Kind of rare, but you run across them occasionally. In the '50s Chrysler used them for wheel lugs on the driver's side--same principle but opposite reason to what Albert said. They seemed to think that RH lugs could cause those wheels to come loose.
Maybe Chrysler still uses them. I don't know.
PostSubject: Re: Backwards bolt?   Mon Jan 10, 2011 11:08 pm
This is truu my dude.
Backwards bolt?
