 Cell phone interfaces
Merit : 153
Cell phone interfaces Empty
PostSubject: Cell phone interfaces   Cell phone interfaces EmptyFri Jan 07, 2011 9:11 pm
'Asking for advice/suggestions on adding a built in cell phone or permanent cell phone interface to a stock '97 or later Riv.
Thanks
PostSubject: Re: Cell phone interfaces   Cell phone interfaces EmptyFri Jan 07, 2011 10:31 pm
Do you mean something like a bluetooth system? I know when I was looking for a new head unit for the Riv(before the CD player immaculately started working again), you could buy different modules that plug in and mount anywhere inside the dashboard for HD radio, bluetooth, etc. If you have an aftermarket head unit already, look into modules for it. They run about $100 and you need to find somewhere to wire the mic to.
If you're on the stock radio, then I don't know enough to help other than suggesting a pair of bluetooth speakers.
Merit : 153
PostSubject: Re: Cell phone interfaces   Cell phone interfaces EmptyMon Jan 10, 2011 12:09 pm
Thanks Ilan.
PostSubject: Re: Cell phone interfaces   Cell phone interfaces EmptyMon Jan 10, 2011 12:38 pm
Yeah. I'm not sure if the factory setup can be modified to incorporate a Bluetooth system. Ilan is correct about the aftermarket setup. My Alpine (for example) required a seperate module ($100) to utilize the Bluetooth/HD radio/XM satellite functions. Once installed, you can simply do a Bluetooth device search while in the car with your phone. It will recognize the radio, and viola! Total handsfree use of your phone through the radio.
c0reyl
c0reyl
PostSubject: Re: Cell phone interfaces   Cell phone interfaces EmptySun Feb 26, 2012 4:23 pm
Might wanna look into this. it's damn pricey, but I plan on getting one eventually.
http://www.pioneerelectronics.com/PUSA/Car/AppRadio/AppRadio+2+(SPH-DA100)
The Roadmaster
The Roadmaster
Name : Carl Alexander
PostSubject: Re: Cell phone interfaces   Cell phone interfaces EmptySat Mar 10, 2012 6:51 pm
Thanks
I knew that sooner or later someone would come along with an integration process.
Here is one that will fit our cars: Blue Tooth Upgrade for Riviera Link
YES!!!
» How much should I be paying on my Rogers Cell Phone bill?
» gps, satellite phone, epirb all on your smart phone
» Off Topic Mobile Phone Numbers
» Verify something online using "your" mobile phone
» Radio Newcastle Football Phone in
