| tranny leak :( | |
| Subject: tranny leak :( Tue May 01, 2007 9:56 am | |
| ok so there has been a constant drip from my tranny now for some time and it was so small i just dismissed it as the gasket seeping. i thought i had overtightened the bolts the last time i changed the filter. i also overfilled it last time so it was never low or even close. never had any shift problems or anything. well, yesterday i drove back home(2hrs at 90mph) got into my parents driveway and 3hrs later had a big puddle of tranny fluid!!! :shock: i got the car warmed up again and checked the fluid. it was still at the full mark. i know our trans had like 14qts and the stuff is so thin a few drops looks like a gallon on slick concrete. i am going to spray it all down with degreaser and see if i can find where it is coming from. but my preliminary guess is the differential cover the puddle seems to be right under the diff and the gasket seems fine on the pan. i will try to take some pics but any advice is much apreciated. what else could it be? input shaft? how much damage ($$) am i looking at if its part of the diff? should i try any tranny stop leak? i never use that crap b/c im worried it will cause more damage than it will fix. TIA Matthew _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
| Subject: Re: tranny leak :( Tue May 01, 2007 4:36 pm | |
| the arrow is pointing to atf it looks like my diff is seeping. so do i need a new differential, tranny, gasket, or what? maybe its time to upgrade to an Intense LSD _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
gosloriv Enthusiast
Name : David Age : 50 Location : Elyria,Ohio Joined : 2007-03-15 Post Count : 152 Merit : 0
| Subject: Re: tranny leak :( Tue May 01, 2007 8:53 pm | |
| Ta me it looks as if u jus need a new seal !!! Its a round metal and rubber one. Pull the shaft and then the seal !!! Should only be a couple of dollers. | |
| Subject: Re: tranny leak :( Tue May 01, 2007 8:58 pm | |
| is the half shaft difficult to pull? _________________ 1996 with 254k miles, L32 4" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs. -RIP AMG C400 White on black. Stage 2 w/E30 - 11.9@117 -daily | |
gosloriv Enthusiast
| Subject: Re: tranny leak :( Tue May 01, 2007 9:14 pm | |
| The half shaft isnt the easiest thing to do.U can jus disconnect the ball joint, jus the nut, then pull the shaft out of the tranny and push it out the way and then pull the seal. | |
TType_Riviera Fanatic
| Subject: Re: tranny leak :( Tue May 01, 2007 9:25 pm | |
| you can use a pry bar to pop the shaft out....drain any fluid also..as it will pour out...there should be a plug in the area to drain from the diff.. | |
| Subject: Re: tranny leak :( Tue May 01, 2007 9:30 pm | |
| the plug is on the pass side of the diff.. | |
riviera301240 Special
Name : superchargered Joined : 2009-09-29 Post Count : 7 Merit : 1
| Subject: Re: tranny leak :( Wed Sep 30, 2009 8:07 pm | |
| Hey I have just spoke of that promblem, and its located near the pan and near the driver side wheel if u do find out this matter pls. Take pic if u can I will look 2 fix it just a reminder after I waited it started reving high in gears so make sure u keep checking the trans flulid when there's a complete stop | |
| Subject: Re: tranny leak :( | |
| tranny leak :( | |
