 Floor Vents Suddenly stopped working.
VJD2
VJD2
Floor Vents Suddenly stopped working. Empty
PostSubject: Floor Vents Suddenly stopped working.   Floor Vents Suddenly stopped working. EmptyWed Jan 26, 2011 10:20 am
I just noticed this the other day during my trip to Detroit. All the vents work except there is no air going to my feet or the passengers feet. This sucks because its freezing out and my feet are getting cold driving!
Has anyone had any experience with this? The head unit is working and switching to floor mode but no air.
How does the system work on the Riv? Vacuum actuated, electronic doors, etc? Any tips on how to resolve it or diagnose?
Thanks.
PostSubject: Re: Floor Vents Suddenly stopped working.   Floor Vents Suddenly stopped working. EmptyWed Jan 26, 2011 11:01 am
See post here:
http://rivperformance.editboard.com/t2500-write-up-hvac-assembly
I know there are a few more posts about it but that write-up shows some of the actuators thumbsup
VJD2
VJD2
PostSubject: Re: Floor Vents Suddenly stopped working.   Floor Vents Suddenly stopped working. EmptyWed Jan 26, 2011 11:12 am
Dammit, I searched too! Apparently not good enough.
Thank you!
97 park ave
97 park ave
Merit : 21
PostSubject: Re: Floor Vents Suddenly stopped working.   Floor Vents Suddenly stopped working. EmptyThu Jan 27, 2011 3:09 pm
Most likely going to be the air mix/blend door actuator. On my park avenue it is located above the kick panel on the drivers side right by the steering column.
VJD2
VJD2
PostSubject: Floor Vents stopped working.   Floor Vents Suddenly stopped working. EmptyWed Jan 18, 2012 10:19 pm
And just in the knick of time for winter temperatures!
Everything else works, defrost and center vents, just no floor heat.
Any ideas on the resolution or if this is another common failure for these cars?
My feet are cold!
Thanks.
Merit : 153
PostSubject: Re: Floor Vents Suddenly stopped working.   Floor Vents Suddenly stopped working. EmptyWed Jan 18, 2012 10:43 pm
My feet are cold!
Thanks.
Do a search on this site for the "actuators" - your probably failed. Significant labor but relatively simple fix with factory or junkyard parts.
VJD2
VJD2
PostSubject: Re: Floor Vents Suddenly stopped working.   Floor Vents Suddenly stopped working. EmptyThu Jan 19, 2012 10:32 am
Just tried that. Didn't work.
Only thing that came up was the boost bypass valve thread unless I'm doing something wrong here.
PostSubject: Re: Floor Vents Suddenly stopped working.   Floor Vents Suddenly stopped working. EmptyThu Jan 19, 2012 11:31 am
VJD2
VJD2
PostSubject: Re: Floor Vents Suddenly stopped working.   Floor Vents Suddenly stopped working. EmptyThu Jan 19, 2012 11:47 am
Thanks Larry!
Merit : 153
PostSubject: Re: Floor Vents Suddenly stopped working.   Floor Vents Suddenly stopped working. EmptyThu Jan 19, 2012 4:23 pm
Yes Larry thank you.
Larry mentioned bookmarking interesting posts.
» Transaxle stopped working out of nowhere
» bite alarm
» Billy's vs E.T vs Predator Alarms vs Fox Micron P's
» Working overtime again
» How has working on your core helped your running
