 Differences in head castings between 96, 97, 98+ prevent using 1.9 rockers?
Bowersk
PostSubject: Differences in head castings between 96, 97, 98+ prevent using 1.9 rockers?   Thu Jan 27, 2011 2:00 pm
Trying to get this order in and I'm confused as hell. Wanting to do 1.9 rockers and springs...what is suggested?
ZZP has the 1.9 modified rockers for $274 if I send in mine first. Then the Comp 105 springs. But what I cant figure out is if I can use the stock retainers and locks?
Problem is I read on another site that setup is not recommended for the 96 L67.
Going to eventually install the XP cam and I know that the 1.9's don't work with that but it didn't seem that was what these folks were talking about.
(been to so many damned sites in the last 2 days I cant remember where I read that at...so I'm asking the people I trust)
http://www.facebook.com/kellybowers79
PostSubject: Re: Differences in head castings between 96, 97, 98+ prevent using 1.9 rockers?   Thu Jan 27, 2011 4:53 pm
Modified rockers will work fine on a 96 (TonySmooth89 ran his forever with no problems). I have a set of modified rockers im looking to get off my hands if you want to go that route.
crlombardi69
PostSubject: Re: Differences in head castings between 96, 97, 98+ prevent using 1.9 rockers?   Thu Jan 27, 2011 5:57 pm
If you're gonna do a cam then you should hold off and put some good roller rockets with the new cam or use the yella Terra or harlan sharpe's with the 1.9 ratio like I did and skip the cam. If I had it to do over I would do the cam change w/good quality roller rockers.
http://crlombardi69@yahoo.com
PostSubject: Re: Differences in head castings between 96, 97, 98+ prevent using 1.9 rockers?   Sat Jan 29, 2011 10:19 pm
ive got the yella tella 1.9's with 105lb compcam valve springs on my 96 and had no problems.
i think I used the stock retainers and new locks.
