 Coolant recovery tank
2 posters
manofmany
Coolant recovery tank Empty
PostSubject: Coolant recovery tank   Coolant recovery tank EmptyWed 2 Feb 2011 - 18:03
Anyone know exactly what I should ask for when I go to the parts store? I can't even find one on rockauto.
Car got stuck in the snow and in the process of getting it out it heated up to about 220 and the coolant boiled up and I found out it had a crack in it. Going to go ahead and replace the tank, thermostat, and LIMG. It cracked in the upper corner where it bolts on and is pretty thing.
Merit : 149
PostSubject: Re: Coolant recovery tank   Coolant recovery tank EmptyWed 2 Feb 2011 - 20:49
You aren't going to find a coolant tank on rock auto. I would get one from Morad, http://www.moradpartscompany.com/
There is also this one on E Bay,
http://cgi.ebay.com/ebaymotors/Dorman-OE-Solutions-603-103-Coolant-Recovery-Tank-_W0QQcmdZViewItemQQfitsZMakeQ3aBuickQ7cModelQ3aRivieraQQhashZitem5aded265f0QQitemZ390285387248QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
manofmany
PostSubject: Re: Coolant recovery tank   Coolant recovery tank EmptyThu 3 Feb 2011 - 12:03
I saw the tank on ebay. If you plug in 97 Riviera it says it won't fit, but it does look similar. Hmmm. I'm guessing worst case scenario I could make it work.
Merit : 149
PostSubject: Re: Coolant recovery tank   Coolant recovery tank EmptyThu 3 Feb 2011 - 13:04
Get one from Morad
» FAQ: Coolant Recovery/Overflow Bottle/Reservoir Options
» torque management, KR recovery rate, etc?
» Write-Up: Fuel Pump/Tank Sending Unit Replacement
» Gas shoots out from tank?
» the tank is always full
