Riv95SC Enthusiast
Name : Riv95SC Location : Nashville, TN Joined : 2010-05-30 Post Count : 115 Merit : 6
| Subject: pulling off the red lens on the door Tue Feb 01, 2011 11:34 pm | |
| Well, the bulb in the red light at the back of my driver's door is out.
I see no obvious way to get the red lens off. That usually means I'll break it for sure if I tear into it.
Anybody know if there's a trick to this?
| Subject: Re: pulling off the red lens on the door Tue Feb 01, 2011 11:51 pm | |
| if you look very closely at the lens you will see how it comes out with a little "help" from a pocket-size screwdriver.
Alternatively you can take the door panel off (easier than it looks, 5 screws) and look at the backside, then it's really obvious how it comes apart.
nebstewart07 Fanatic
Name : Ben Stewart Age : 34 Location : Schofiel Barracks, HI Joined : 2010-12-12 Post Count : 390 Merit : 6
| Subject: Re: pulling off the red lens on the door Wed Feb 02, 2011 12:03 am | |
| put a flat screwdriver on the side of the light closest to the door handle push to the outside of the door panel and pull the red light out. Then unplug the light by turning it and pop it out. | |
Karma Aficionado
| Subject: Re: pulling off the red lens on the door Wed Feb 02, 2011 8:24 am | |
| _________________ | |
| Subject: Re: pulling off the red lens on the door Wed Feb 02, 2011 10:03 am | |
| Neb hit it on the head. Yep, lil screwdriver on the side closest to the handle. Be careful.....It's either that or pull the door panel off. | |
| Subject: Re: pulling off the red lens on the door Wed Feb 02, 2011 1:17 pm | |
| If you break it my dad has ten other ones so i can get you one lol. | |
| Subject: Re: pulling off the red lens on the door | |
