 DHP odd issue with reading DTCs...
Merit: 31
PostSubject: DHP odd issue with reading DTCs...   Wed Feb 02, 2011 5:40 pm
Anyone had issues with freezing when it's reading codes? I can clear the DTCs but not grab them anymore. Can't stand this tuner. Should have gotten HPT but didn't want to deal with the $$$$ involved. Only happens with the Riv and I wonder if that has something to do with it being a 1997.
Merit: 83
PostSubject: Re: DHP odd issue with reading DTCs...   Wed Feb 02, 2011 8:46 pm
afraid I'm not much help with your problem.
but THIS I understand completely. Worlds of possibilities open up when you go HPT (my '05 truck, etc etc) that you are locked out of with DHP.
Merit: 172
PostSubject: Re: DHP odd issue with reading DTCs...   Thu Feb 03, 2011 9:48 am
I've never had an issue with DHP software. It's one of the more reliable products I've purchased, even if it doesn't do everything HPT can. And as I've found out recently, those who've spent money on HPT may be regretting it - this product makes your DHP even more powerful than a stand-alone HTP!
- John R. White, Boston Globe
Merit: 31
PostSubject: Re: DHP odd issue with reading DTCs...   Thu Feb 03, 2011 4:03 pm
I think DHP can actually change the temp at which the PCM looks for knock (some models it's 160* if memory serves) but HPT cannot. But I think that's it. LOL
Whatever the issue was with the code read, I was able to get the code previous to that and edit the tune so that it does not report (code was P0141 rolleyes ). Might be looking at an issue with the front O2 sensor I think. Damnit frown
edit: wait... that looks to be rear O2. that's what i initially thought
Merit: 172
PostSubject: Re: DHP odd issue with reading DTCs...   Thu Feb 03, 2011 4:17 pm
DHP can definately change the knock sensor activation temp. If HTP can't do this, I'm really glad I have DHP, lol. That's surprising to me if it's true.
» Seagull 1963 Chinese Air Force re-issue
» Bad Lip Reading
» a reading please
» Adjust Odo Reading
» LOTS OF READING IN PAPERS TODAY - HOME PARK RENT....
