 Could I swap my 97 Riv with a 3800 series 3 engine w/superch
dev919
6 posters
dev919
dev919
Location : washington dc.....clinton, md......in college down greensboro, nc
Could I swap my 97 Riv with a 3800 series 3 engine w/superch Empty
PostSubject: Could I swap my 97 Riv with a 3800 series 3 engine w/superch   Could I swap my 97 Riv with a 3800 series 3 engine w/superch EmptyMon Jul 27, 2009 2:24 pm
I ran across a 2004 Pontiac Grand Prix engine, which is 3800 series 3 supercharges, and I wanted to know is it possible to swap these, and if so wats the pros and cons
PostSubject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch   Could I swap my 97 Riv with a 3800 series 3 engine w/superch EmptyMon Jul 27, 2009 3:36 pm
L32 block is basically the same. few small changes like a different starter IIRC.
The big difference is the gen V supercharger that is used vs our gen 3 blower.
You can pick up a gen V for about $500 with all the necessary stuff to put it on the riv. (minus the tune)
the benefit is more power due to a more efficient blower, so if you have the money and ability to tune the car then i say go for it!
however it is much easier to swap just the S/C's rather than the entire motor, unless yours isnt running.
Could I swap my 97 Riv with a 3800 series 3 engine w/superch Dsc_0110
dev919
dev919
PostSubject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch   Could I swap my 97 Riv with a 3800 series 3 engine w/superch EmptyMon Jul 27, 2009 3:54 pm
naw its running but my riv got about 225k on it and i figured it wouldnt last much longer, and the total swap would be cost efficient seeing that the engine has only 55k and it comes supercharged as well...
Also how much should just a Gen V SC be?
here is the website where i found the actual engines for sale
http://www.automotix.net/usedengines/2004-pontiac-grand_prix-inventory.html
PostSubject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch   Could I swap my 97 Riv with a 3800 series 3 engine w/superch EmptyMon Jul 27, 2009 4:13 pm
As Mr. Riviera said above you can find a used Gen 5 supercharger and L32 intake manifold used sometimes for $500.00-$600.00 but you have to be looking otherwise I've seen some people ask a lot more and that's just SC and Manifold.
If you can get a low mile L32 complete with SC for under a $1000.00 delivered, I'd say grab it and do the swap.
PostSubject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch   Could I swap my 97 Riv with a 3800 series 3 engine w/superch EmptyTue Jul 28, 2009 1:41 pm
I agree. Even If you don't feel like doing the whole swap right away, you can keep the motor around. How's the transmission with those miles? Has it been replaced or rebuilt yet?
dev919
dev919
PostSubject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch   Could I swap my 97 Riv with a 3800 series 3 engine w/superch EmptyTue Jul 28, 2009 1:54 pm
Its still good actually...still got that punch...where could i find jus the gen V SC?
dev919
dev919
PostSubject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch   Could I swap my 97 Riv with a 3800 series 3 engine w/superch EmptyTue Jul 28, 2009 2:18 pm
also if i jus get the supercharger the only other thing i need is the coupling rite
PostSubject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch   Could I swap my 97 Riv with a 3800 series 3 engine w/superch EmptyTue Jul 28, 2009 2:33 pm
You need to do a lot more reading on here Devlin.
Go to the "Write Ups" section to start.
There is someone on here currently doing the L32 engine with a Gen V SC swap. Follow his thread for a while and you'll get an idea what you are getting into.
Also, If you can get that engine you talked about with the supercharger complete delivered to you for under a $1000.00, you will save a lot of money, time and aggravation in my opinion.
L8-2BNGO
PostSubject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch   Could I swap my 97 Riv with a 3800 series 3 engine w/superch EmptyTue Aug 04, 2009 9:14 pm
hey hey hey theres only one Devin allowed on this forum and i was here first!!! lol jk
apu711
PostSubject: Re: Could I swap my 97 Riv with a 3800 series 3 engine w/superch   Could I swap my 97 Riv with a 3800 series 3 engine w/superch EmptySat Feb 05, 2011 6:40 pm
hey my names devin too!! i have a 95 riv with a series one 3800 supercharged, how difficult is it to swap with a series 3 3800 supercharged??
» Series III 3 engine swap
» 3800 camaro swap
» series 2 parts on series 3 engine
» Write-Up: 3800 Series II SC Engine Removal & Installation
» Ignition Coil Pack part # for Supercharged 3800 Series II Engine?
