super6riv Special
Name : Frankie Joined : 2011-02-15 Post Count : 1 Merit : 0
| Subject: 97 riv, noise in front passenger side when roads are wet Tue Feb 15, 2011 7:14 pm | |
| hello and thanks in advance, im getting a wop wop wop in the front passenger side wheel area only when the roads are wet and speeds over 50. anyone have this problem too? | |
Jamax Enthusiast
Name : Jim Fleck Location : Crystal River, FL Joined : 2010-06-24 Post Count : 143 Merit : 8
| Subject: Re: 97 riv, noise in front passenger side when roads are wet Tue Feb 15, 2011 7:50 pm | |
| I'm certainly no expert--you can count on one or more chiming in here--but the first thing I always check is the tire itself. Not just visually, but by running my hand slowly over every inch of surface including both sidewalls. I've found some really bad things that way that pased a visual inspection. In an event, good luck. | |
| Subject: Re: 97 riv, noise in front passenger side when roads are wet Tue Feb 15, 2011 8:26 pm | |
| You should rotate your tires front to back and see if the noise follows the wheel. If so have a pro look at your tires. | |
| Subject: Re: 97 riv, noise in front passenger side when roads are wet Tue Feb 15, 2011 8:33 pm | |
| Subject: Re: 97 riv, noise in front passenger side when roads are wet | |
