 3/4 to full throttle miss,chug
tgrath
3/4 to full throttle miss,chug Empty
PostSubject: 3/4 to full throttle miss,chug   3/4 to full throttle miss,chug EmptyWed Feb 16, 2011 8:19 pm
hi all, 95 sc riv with cai,cat and resonator delete, car runs perfect,but at times at 3/4 to full throttle it seems to have a slight miss or chug, no check eng lights, any ideas?
PostSubject: Re: 3/4 to full throttle miss,chug   3/4 to full throttle miss,chug EmptyWed Feb 16, 2011 8:32 pm
maybe ignition wires?
PostSubject: Re: 3/4 to full throttle miss,chug   3/4 to full throttle miss,chug EmptyWed Feb 16, 2011 8:54 pm
Owning a 95 myself,it can be a dozen problems.fouled Injectors.faulty TPS,clogged AIC valve,vac leaks..etc..etc..
If you have all original equipment that's been baking underhood since 95 all parts are suspect. I have repaired,replaced,cleaned, all above mentioned parts at some time since i bought the car in 05 ,and after addressing these issues,the symptoms you mentioned,they went away.
It also might help if you gave a little more info other than a "howdy" and "any ideas" mileage, past repairs,etc....
tgrath
PostSubject: Re: 3/4 to full throttle miss,chug   3/4 to full throttle miss,chug EmptySun Mar 20, 2011 2:21 pm
it was wires, they looked good, but as usual, until you change them, you cant see how bad they are.thanks, without this site my car would be in the junkyard!
PostSubject: Re: 3/4 to full throttle miss,chug   3/4 to full throttle miss,chug EmptySun Mar 20, 2011 2:25 pm
Thanks for the update! Glad to hear your car is running well again.
» FULL THROTTLE EVENT Trails End Memorial Day Weekend
» Trails End Full Throttle featuring Trace Adkins
» 2014 Full Throttle Event @ Trails End featuring Craig Morgan
» Murder and Mayhem at Traailsend Full Throtle event
» Briggs and Stratton runs on after throttle is closed
