 90-93 cd player
jayeli
jayeli
90-93 cd player Empty
PostSubject: 90-93 cd player   90-93 cd player EmptyFri Feb 18, 2011 8:56 pm
the only thing that doesn't work on my 90 with 37k is the cd player, which is separate from the radio. it tries to play the cd for a bit, then ejects it. does anyone know anything about the 90-93 cd players? i'd like to just update the entire system, but i have to keep it "on the cheap" (mean wife!). nono
BlownRiv
PostSubject: Re: 90-93 cd player   90-93 cd player EmptySat Mar 12, 2011 11:14 am
I had problems with this exact unit. Only when it was hot was I able to get it to work. I would have to constantly insert and re-insert a cd for nearly 5 mins to get it to kick in. Your best bet is to pull a newer GM deck with seperate player. It will plug right into your Riviera and should mount with no problems. Essentially your just putting in an updated version of what you have.
You can find these in safari/astro vans and GM pickups. Some have deck mount cd with tape unit below or vise versa. This setup can is also dirt cheap to buy.
90-93 cd player Parrot32006
90-93 cd player 41618120
jayeli
jayeli
PostSubject: Re: 90-93 cd player   90-93 cd player EmptySat Mar 12, 2011 12:50 pm
what years of astro/safari or silverado/sierra should i look for?
the riviera cd player has separate buttons though...how would i control the cd palyer?
90-93 cd player 90_1
BlownRiv
PostSubject: Re: 90-93 cd player   90-93 cd player EmptySat Mar 12, 2011 2:07 pm
Yep I had that (bose) setup in my old riv years back. With this newer setup the cd functions are controlled by the head unit rather then by itself like the older model.
For astro and safari vans look in 1995-2005 (anything with the newer resigned dash) and also 95-2002 chev/gmc pickups, yukons etc newer body style and older all carried the same setups until 03 when they went with double din). If you find the lower cd section but not the upper just look in random GM cars they are all plug and play and you will find the exact same unit. Pontiac decks will also work but will light up in red.
Another thing to keep in mind is if you want to ditch the tape another factory cd unit will bolt/plug right in.. Making your old cd unit just a part of the dash.
For example
90-93 cd player 31874720066_large
Or you can just grab a newer cd unit only like the one pictured above in the astro/pickup. They all work and plug in direct.
PostSubject: Re: 90-93 cd player   90-93 cd player EmptySun Mar 13, 2011 10:26 am
They used the same remote CD player in the '95 Riv, and maybe even the '96. Possibly find one from a newer model and use that? If originality is what you are looking for maybe that would be the way to go?
PostSubject: Re: 90-93 cd player   90-93 cd player EmptyMon Mar 14, 2011 11:42 pm
My 92 has the same,a very nice setup and sound,works great.
jayeli
jayeli
PostSubject: Re: 90-93 cd player   90-93 cd player EmptyTue Mar 15, 2011 9:16 pm
blownriv- when you say to look for the newer single unit, will it plug right in without modifying the wires or harness?
99rivman- same thing-would a newer riviera's unit plug directly in without modicication?
flyineagle96- what is the "setup" you have on your 92-an astro/safari single unit or a newer riviera unit?
thanks everyone!
PostSubject: Re: 90-93 cd player   90-93 cd player EmptyTue Mar 15, 2011 9:55 pm
It's the stock 92 just like the one you have,a very good sounding system.Mine works great cd and cassette.
BlownRiv
PostSubject: Re: 90-93 cd player   90-93 cd player EmptyWed Mar 16, 2011 6:50 am
Yep GM used the same plug all the way into the mid 2000's. Most of the mounting is the same too. The newer delco decks are slightly deeper but thats all. I have put these decks in a ton of various GM's from the mid 80s to the late 90s. You can always post a pic of the deck your getting if you want confirmation.
PostSubject: Re: 90-93 cd player   90-93 cd player EmptyFri Mar 18, 2011 9:20 pm
I don't know about the newer years, late '90s and into 2000, but the '95 and '96 CD player with all of the buttons would be a direct fit. I'm not sure how the ones that have no buttons on them would work but they might?
jayeli
jayeli
PostSubject: Re: 90-93 cd player   90-93 cd player EmptyTue Aug 23, 2011 1:02 pm
in the end, i just decided to leave the old radio in and use a cassette adapter to listen to music on my mp3 player instead-it works great!
90-93 cd player
» McDonald's Mini player commercials
» Who is the best Gr. 9 player in Peel??
» Player Fact Files
» Which Premiership player has scored the most goals in a season?
» Leinster Leader Player Ratings
