 wierd
amaidendevil
wierd  Empty
PostSubject: wierd    wierd  EmptySat Feb 26, 2011 6:14 pm
i replaced o2 sensor on my 95 riv now i have avibration when i accelerate let off gas no vibration coasts great
wierd  Empty
PostSubject: Re: wierd    wierd  EmptySat Feb 26, 2011 6:17 pm
holy shit
wierd  Empty
PostSubject: Re: wierd    wierd  EmptySat Feb 26, 2011 6:22 pm
Did you do anything else to the car? What kind of vibration is it? Like a rattle?
wierd  Empty
PostSubject: Re: wierd    wierd  EmptySat Feb 26, 2011 7:21 pm
Did you unplug your rear spark plug wires to get more room while you were changing out the O2? If so you may have crossed them, or not fully seated them back on.
wierd  Empty
PostSubject: Re: wierd    wierd  EmptySun Feb 27, 2011 12:42 am
This makes no sense unless you moved an exhaust shield or something... I don't know of anything else. :/
amaidendevil
wierd  Empty
PostSubject: Re: wierd    wierd  EmptySun Feb 27, 2011 11:54 am
no unhooked o2 sensor from above engine dad went under car and took o2 sensor out didnt unhook anything else and when i give gas going down road its like a go kart on a gravel road
Merit : 154
wierd  Empty
PostSubject: Re: wierd    wierd  EmptySun Feb 27, 2011 8:47 pm
the noise is probably a coincidence, somthing else that was going that's finally let go... have you checked the body-cradle mounts?
amaidendevil
wierd  Empty
PostSubject: Re: wierd    wierd  EmptySun Feb 27, 2011 9:01 pm
solved problem when my dad was changing the o2 sensor he accidently knocked the spark plug wire out of the clip with out knowing and it laid on exhaust manifold and melted causing it to misfire and vibrate while driving haha always something stupid
wierd  Empty
PostSubject: Re: wierd    wierd  EmptySun Feb 27, 2011 9:06 pm
I think you should beat your father severely while he sleeps and cave in his solar plexus with a blunt object like a cast iron cylinder head.
wierd  Empty
wierd
» weird things
