 Ignition Coil Packs
NO 4 EVR
PostSubject: Ignition Coil Packs   Wed Mar 07, 2007 5:05 pm
Coil pack replacement is easy right?
Merit : 99
PostSubject: Re: Ignition Coil Packs   Wed Mar 07, 2007 5:07 pm
very easy, they are right on top.
1996 with 254k miles, L324" FWI -> ported N* -> Ported Gen V w/3.0" Pulley, Stage 3 Phenolic I/C, ZZP FMHE, 1.84 RR, Headers and 3" pipe to mufflers, F-body brakes, and lowered on Eibachs.
PostSubject: Re: Ignition Coil Packs   Wed Mar 07, 2007 5:12 pm
Eww...Good question. Here's another...Should the coil pack be replaced after so long? If you have 100k+ and have never replaced it, Is it just bad when it's out, or should it be a time change thingy? (you know this is going to get moved...don't cha?!:roll: )
PostSubject: Re: Ignition Coil Packs   Wed Mar 07, 2007 6:41 pm
I would only replace it if you have a problem.
Merit : 239
PostSubject: Re: Ignition Coil Packs   Wed Mar 07, 2007 6:55 pm
agree They aren't exactly cheap, either.
^^^ RIV IS FOR SALE! ^^^
SoCal Riv
PostSubject: Re: Ignition Coil Packs   Wed Mar 07, 2007 7:11 pm
So what is the least expensive price members have found for a coil pack?
Merit : 99
PostSubject: Re: Ignition Coil Packs   Wed Mar 07, 2007 7:18 pm
junk yard ones are cheap happy
autozone has them for $24 each, but the dealer will have the best ones IMO, since mine are still stock at 125k miles. they have a good reputaion wink
PostSubject: Re: Ignition Coil Packs   Wed Mar 07, 2007 9:21 pm
What makes you think you need to replace a coil pack?
I've seen bad plugs or wires mislead techs to replacing unneeded coil packs. They rarely fail.
NO 4 EVR
PostSubject: Re: Ignition Coil Packs   Sat Mar 10, 2007 4:44 pm
Number 2 blew, which leads me to believe that 1 and 3 COULD go any time now. My roommate found some online for 54 bones I believe.
I know they are on top but I wasnt sure if things would fly out at me like springs or something. For some reason I get the idea there is loose parts under it.
lionfish
PostSubject: Re: Ignition Coil Packs   Sun Mar 11, 2007 9:05 pm
The Coil packs in my 95 lasted 7.5 years and 135K miles. The part number for the
95/ L36 Coil Assembly is 10472401. GMpartsdirect.com sells them for $33 each. The dealer installed mine and they are covered by the GM Goodwrench Limited Lifetime Warranty.
NO 4 EVR
PostSubject: Re: Ignition Coil Packs   Mon Mar 12, 2007 1:14 pm
Thanks for the info lionfish
Merit : 123
PostSubject: ignition coils   Wed May 02, 2007 8:11 pm
PostSubject: Re: Ignition Coil Packs   Wed May 02, 2007 10:26 pm
stock L67 coils have the same output as MSD or ACCEL. #800 cars in the 11s still use stock igntion. No need to upgrade.
NO 4 EVR
PostSubject: Re: Ignition Coil Packs   Wed May 02, 2007 10:28 pm
Good to know
Merit : 239
PostSubject: Re: Ignition Coil Packs   Wed May 02, 2007 10:36 pm
GM coils do put out some really hot spark.
Merit : 123
PostSubject: Re: Ignition Coil Packs   Wed May 02, 2007 10:41 pm
I beg to differ. 30k volts and 45k volts are not the same output. but i understand your point and aa's that the stock coils are sufficient.
tell me if this just sounds retarded but i figured a higher output coil would allow use of much colder (4 ranges or so) spark plugs in everyday driving and racing without any fouling or incomplete burns
PostSubject: Re: Ignition Coil Packs   Wed May 02, 2007 10:46 pm
where did you get the 30k - 45 k specs from?
Most of the fastest cars have stock ignitions. there are better ways to spend $120.00
Merit : 239
PostSubject: Re: Ignition Coil Packs   Thu May 03, 2007 8:48 am
The error in reasoning that higher ignition voltage will allow you to run colder plugs is: you assume higher voltage has something to do electrode temperature, which it does not. The temp of the plug has more to do with cylinder temps, resulting from a combination of factors (not spark).
Even if higher voltages did create extra heat in the plug, going cooler would only bring you back to where you started, so no gains to be had. Read our FAQ on plugs: http://rivperformance.editboard.com/Supercharged-3800-Tech-c2/Series-II-FAQ-f19/Which-spark-plugs-should-I-use-t26-0.htm
The biggest difference with aftermarket coils is the color of the housing. You can easily paint the OEM cases red or yellow to get the same effect.
Merit : 123
PostSubject: bad parts   Wed Oct 24, 2007 7:48 pm
Just putting it out there...
The high performance DIS ignition coils that ACCEL makes, in addition to having no measurable benefit, are a very poor product as I have experienced in the past few months.
I got the three and installed them and in a about a week, two of them just quit almost at the same time while I was driving the car. I exchanged the two and got about another two or three months out of them before one failed again. (I was 40 miles away from a good coil so that sucked - one way to really test your cats ability to neutralize hydrocarbons)
In addition to the obvious failure, one or more of them had apparently been the cause for a less easy to point out WOT, high rpm misfire condition for a couple weeks before the one failed altogether. If it hadn't failed, I would still be scratching my head at the condition today that I suspected the cat. of causing.
Thankfully, I didn't pay for them so I'll just consider it an inconvenient product trial.
long story short, don't invest in these coils. They do nothing but cause headaches. I should clarify that I have no experience with the coils that MSD make so I cannot testify that those are an equally poor product. But we don't sell those at my work so I can't test them.
PostSubject: Re: Ignition Coil Packs   Wed Oct 24, 2007 8:47 pm
Sorry for your troubles with those coils. Most of what I've read indicates that the OEM coils perform as well as any aftermarket parts. I went with OEM coils this summer, and kept my originals as backups.
Merit : 239
PostSubject: Re: Ignition Coil Packs   Thu Oct 25, 2007 8:15 am
I hear more about aftermarket coils failing than OEM. I've never had a problem with my originals.
PostSubject: Re: Ignition Coil Packs   Mon Dec 03, 2007 9:44 pm
I used to work at a speed shop. Accel ignition parts definitely had a failure rate higher than normal, and I had a few bad experiences personally. I never have problems with MSD stuff.
Merit : 239
PostSubject: Re: Ignition Coil Packs   Mon Dec 03, 2007 10:38 pm
Somewhere I thought I read that MSD used the same internal parts as OEM, or vice-versa. So you're paying more for the red plastic, basically. Anyone know about this for sure?
PostSubject: Re: Ignition Coil Packs   Mon Jan 14, 2008 2:36 pm
My coils haven't gone bad yet but the posts are very corroded. I plan on changing them out today. I have heard that the aftermarket coils (MSD, Accel, etc...) are made for the 3800 normally asperated engines. OEM are the only good replacement for SC applications from everything I've heard...
Merit : 239
PostSubject: Re: Ignition Coil Packs   Mon Jan 14, 2008 3:14 pm
Have the coil posts always been corroded, or is this something that you see happening over time?
Ignition Coil Packs
» Ignition Coil Spark Voltage
» coil packs going out? need help fast!
» Leaking Ignition Coil
» Ignition Coil
» Ignition Coil Packs
