| Power Seat Problems - Seat Leans or Wont Move | |
+26cryoburned DEMonte1997 pbrktrt Andysdorm otto95 rk0ehn flyineagle96 VincentVega Fastbuick95 BigRay1125 96scriviera Joby70739 BMD robotennis61 GMFreak8 T Riley deekster_caddy ibmoses Eldo Rickw albertj rivman96 R1V13RA BrokenDownInTheYard blackbart95 SupersportSteve 30 posters |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Sun Feb 20, 2011 10:44 pm | |
| - albertj wrote:
- robotennis61 wrote:
- there are no cables in the Riv seats.They are operated via a long Screw..At least thats the way it is a 95.most likely the screw track is damaged.its a white plastic
I thought he meant the electric cables to the motors.
Arent they just gears? I could be wrong.... | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Sun Feb 20, 2011 10:46 pm | |
The motors have wires to them for electricity. Some people like to put stuff on the floor of the car and slide it under the seats, which is a bad idea in the Riv. Albertj | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Tue Feb 22, 2011 2:44 am | |
| I'm pretty sure he's referring to the drive-cables at the front of the seat, which transfer force from the motor to the worm-screws that run down the sides of the seat... which would probably best be had at a wrecking yard. I'd bet there are a lot of GM bucket seats that use that system, and a flash light and extension mirror would find 'em before pulling the seat bolts. | |
96scriviera Amateur
Name : steve b Joined : 2011-02-13 Post Count : 23 Merit : 0
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Tue Feb 22, 2011 3:29 am | |
| - Eldo wrote:
- I'm pretty sure he's referring to the drive-cables at the front of the seat, which transfer force from the motor to the worm-screws that run down the sides of the seat... which would probably best be had at a wrecking yard. I'd bet there are a lot of GM bucket seats that use that system, and a flash light and extension mirror would find 'em before pulling the seat bolts.
exactly what im talking about lol!!!!! i think we can fix the ganasta lean without replacing them..t the power recline wont work but at least the seat will sit even | |
BigRay1125 Enthusiast
Name : Ray Age : 55 Location : Pittsburgh PA Joined : 2008-01-22 Post Count : 148 Merit : 5
| Subject: Power Seat Problems - Seats Wont Move Tue Mar 01, 2011 8:58 am | |
| In My 95 Riviera The Driver Side Seat Wont Move From The Switch On The Seat But Will Move From The Memory on The Door HELP Is It The Switch On The Seat Or What | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Tue Mar 01, 2011 3:47 pm | |
| '95 had a totally different Remote Entry system and may well have a totally different seat/memory system... On my own '97, If the memory functions then all the fuses & breakers are good.
Do none of the manual seat switches work on your car? If so, the only think I can think of is a bad connection or break in the fat red wire that feeds the switch. | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Tue Mar 01, 2011 8:13 pm | |
| The Switch Does Nothing Forward Backward Or Recline But If You Press #1 Or #2 On The Door It Will Adjust To Driver 1 & 2 Even The Exit | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Tue Mar 01, 2011 8:31 pm | |
| - BigRay1125 wrote:
- The Switch Does Nothing Forward Backward Or Recline But If You Press #1 Or #2 On The Door It Will Adjust To Driver 1 & 2 Even The Exit
Well, I'd say the recline is the kicker - that one doesn't go through the memory module. So unless the guts of the switch have come apart, you're going to be tracking down the positive feed to the swich. If you have the FSM, get out the schematics to confirm that there is not a fuse that feeds only the switch, otherwise start by removing the switch and testing the feed with a meter or test lamp. Good luck! | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Tue Mar 01, 2011 8:49 pm | |
| Thanx For Your Help I Was Hopeing It Would Be The Switch Easy Fix | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Wed Mar 09, 2011 7:41 pm | |
| HEY ELDO IF THE SEAT IS MOVING VIA MEMORY WOULDNT THAT MEAN ITS GETTING POWER ? | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Wed Mar 09, 2011 9:03 pm | |
| - BigRay1125 wrote:
- HEY ELDO IF THE SEAT IS MOVING VIA MEMORY WOULDNT THAT MEAN ITS GETTING POWER ?
...what you missed is that the memory does not adjust the rake of the seatback. It adjusts the tilt of the seat cushion. Albertj | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Wed Mar 09, 2011 10:13 pm | |
Ray- Yes, which is why I said earlier that "On my own '97, If the memory functions then all the fuses & breakers are good."Therefore the problem has to be with the manual switch or the (+) wire feeding it. Albert- I didn't miss the recline, I added it to the previous evidence: the memory may work for the other adjustments, but there has to be power to the manual switch to work the recliner... Ergo, the switch or the (+) wire. | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Thu Mar 10, 2011 1:35 pm | |
| - Eldo wrote:
Ray- Yes, which is why I said earlier that "On my own '97, If the memory functions then all the fuses & breakers are good." Therefore the problem has to be with the manual switch or the (+) wire feeding it.
Hi Eldo, you did not miss it, I think Ray inadvertently did. Prolly not important at this point anyway. do you think that at this point, thing to do is either get the switch out and check the wiring (it's way easier to work on with the switch out) or pull the seat then troubleshoot - problem with pulling the seat is you have to scoot it all the way fwd to expose the bolts. Only 2 hold it in, the front has hooks that engage slots in the floor pan. Ray if you need more on how to do this troubleshooting you might want to re-post. There was a good pointer I put on this site to another site that taught how to troubleshoot with a multimeter, but I can't find it at the moment. A multimeter will cost less than $30 fro walmart or radioshack. IIRC the switches can be partly disassembled and may be repairable. Usually worn contacts can be renewed with dots of rosincore solder, and old clotted grease dissolved with deep creep or wd40 and replaced with tune-up grease (the stuff can be purchased in little paks for a buck at most auto parts stores counters). Albertj | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Thu Mar 10, 2011 2:37 pm | |
| Yes, at this point I still advise pulling the switch & checking both it and the connector for damage. Also, he can jumper across the connector to test that way as well.
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Tue Mar 22, 2011 9:37 pm | |
| Today I Tested The Seat & Its Not The Switch The Switch Isnt Getting Power So I Jumped It To Move It So I Can Remove The Seat To find The Problem ...Sorry I Missed what Y`all Said I Guess i Was Listening Wit My Ears Wide Shut ............Thanx ELDO & albertj | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Tue Mar 22, 2011 11:11 pm | |
| - BigRay1125 wrote:
- Today I Tested The Seat & Its Not The Switch The Switch Isnt Getting Power So I Jumped It To Move It So I Can Remove The Seat To find The Problem ...Sorry I Missed what Y`all Said I Guess i Was Listening Wit My Ears Wide Shut ............Thanx ELDO & albertj
You're welcome of course. Give you a hint. The bundle of wires to the power seat probably got pinched in the seat track at some point, or the wire broke off in the pin connector crimp in one or another side of the connector. Careful visual inspection should reveal the actual problem. I am *very* glad you found the problem was not the switch - this is why testing is so important. Now I gotta go pack. Albertj | |
Fastbuick95 Enthusiast
Name : Chris Harvey Age : 32 Location : Grand Blanc Joined : 2010-06-07 Post Count : 117 Merit : 1
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Wed Mar 23, 2011 1:32 pm | |
| I had the same problem, I don't know if it will be as simple as a fix for you, but under the seat, there were wires under my seat that were like twisted up and as soon as I unraveled those wires the seat worked just fine like it should, hope this helps | |
| Oh, he already said what I did. my bad lol | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Wed Mar 23, 2011 3:31 pm | |
| I HOPE IT IS THAT SIMPLE ....THANX | |
VincentVega Special
Name : Meh Joined : 2011-04-12 Post Count : 2 Merit : 0
| Subject: Driver seat works off and on and when not working it beeps & Supercharger Q Tue Apr 12, 2011 8:25 pm | |
| Hey everyone!
Just bought a 95 Riv today and it has a few issues.
The drivers seat will work and then sometimes it wont. Seems like there is no rhyme or reason for it. Also when it is not working there is a constant, and annoying, beaping or churping coming from under the seat.
I'm thinking maybe a ground? But before I go digging I figured I's ask some fellow owners to see if anyone has had a similar issue.
Second questions is when you get on these cars should you feel the supercharger kick in? I've never had a SC car but I have had turbo fed cars and I could feel the turbo when I got on them.
Thanks for any help or recommendations! | |
flyineagle96 Junkie
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Tue Apr 12, 2011 8:29 pm | |
| No spooley in the super charger....... | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Wed Apr 13, 2011 12:10 am | |
| My 95 had a similar issue with the seat.Apparently some wiring behind the seat control panel can chafe.unscrew the panel cover and check things out.mine was sparking all over the place. | |
VincentVega Special
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Wed Apr 13, 2011 5:34 am | |
| Thanks,
I'll open that up and check it out! | |
rk0ehn Enthusiast
Name : Christian Rolf Köhn Age : 34 Location : CD Juarez, MX Joined : 2011-08-11 Post Count : 148 Merit : 14
| Subject: Power Seats Not Working Sat Aug 13, 2011 3:43 pm | |
| I just got a Riviera 1995 Supercharged series I 3 days ago and as I was looking for a Haynes manual desperately online But I had no luck so yesterday I found this helpful forum and looking to find a solution for my problem with my Power Seats. The problem I have is that they don't work, the car itself is not on very good conditions but I like the car and would like to repair it as much as I can, so the driver side is in a very front position to the point that my knees are very near to the bottom of the dashboard and I can't drive very well, so it will be the very first thing I need to repair. OK, now the issue here is that the switch is completely broken doesn't work at all not even for trouble shooting, and unfortunately I can't take off the seat because is not forward enough to reach the bolts and I can't access the bottom of it very well, so yesterday the passenger's side was working but as I was looking through the fuse box on the rear seat and I noticed that the PWR ST 25amp CB got very hot and I took it off and tried to put it back in, but it made a spark and I can't use it so obviously there is a very big short, so what I’m trying to do is to get a wiring diagram or if you can tell which wire is the one I can power at the switch (because I was able to open the switch) so the seat can get forward enough so I can take it off and inspect it for any issues. If you have any ideas on how I can fix my problem I would GREATLY appreciate it Thanks! | |
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move Sat Aug 13, 2011 10:00 pm | |
| First, check the seat power thermal fuses. I bet that one or both of the power seat thermal breakers are very hot. Remove the hot one with a pair of pliers holding it gently so you don't break it and let it cool off.
Nest get a flashlight and look under the seat. Gently pull the wires away from the seat tracks.
When the thermal breakers cool off then try putting them back in and moving the seat switches. They may start working. Even so, DO NOT reinstall the thermal breakers until you check the wires and pull them away from the seat tracks. All they will do is shoot sparks like you noticed. That is - simply removing and reinstalling the breaker will not fix the short circuit. What you are doing is removing the breaker until you actually find the problem cause, so that other electrical stuff does not get messed up in the meantime.
Oh by the way, unless your switch got water/mud in it, the problem's not very likely to be the switch. Because of the way the wires are routed and the tie-downs break, the problem is likely to be the wiring.
| Subject: Re: Power Seat Problems - Seat Leans or Wont Move | |
