 95 OBD Connector Pinout
2 posters
jadmonkey
95 OBD Connector Pinout Empty
PostSubject: 95 OBD Connector Pinout   95 OBD Connector Pinout EmptySat Mar 19, 2011 7:02 am
In case anyone wants to know exactly what the pinout of the OBD2 connector that is on the 95 model, and where those pins lead.
pin 4, circuit 150, Black, Battery Minus
pin 5, circuit 251, Black/White, Battery Minus, tied to engine block
pin 8, circuit 1455, Black/White, RAC Data (keyless entry/locks) Used for programming keyless entry.
pin 9, circuit 800, Tan, Data line, UART, (Connects PCM, DERM, HVAC PROG, RAC, EBCM, Instrument Cluster)
pin 11, circuit 345, White, Power Steering (Connects to one side of the actuator)
pin 14, circuit 835, Dark Green, Data, (Connects to HVAC PROG, HVAC Control, and Radio/CD)
pin 16, circuit 40, Orange, Battery Positive
Hopefully this helps someone. And dispels that paper clip idea.
PostSubject: Re: 95 OBD Connector Pinout   95 OBD Connector Pinout EmptySat Mar 19, 2011 10:30 am
Thanks, jadmonkey. Much appreciated!
» Calling those with a 1999 FSM - data link connector pinout
» Can any one name this connector?
» Name that connector part 2
» Pic of OBD-II connector under DS dash?
» Engine Wiring Harness Diagrams - Series II SC
Riv Performance ::   Supercharged 3800 Tech :: Series I Scans & Tuning-
