| Starts and dies, starts and dies. | |
YO MUDA Amateur
Name : Jimi Age : 65 Location : norman okieHOMER Joined : 2010-06-28 Post Count : 25 Merit : 0
| Subject: Starts and dies, starts and dies. Wed Mar 30, 2011 6:25 pm | |
| 95 SC. Drove to work this morning. Ready to go home, now she will start, run for 1 or 2 seconds and dies. I hear fuel pump running on start. Any ideas, or things to check. I hate leaving it at work. | |
BMD Aficionado
| Subject: Re: Starts and dies, starts and dies. Wed Mar 30, 2011 8:32 pm | |
| My dads supercharged Park Ave has been having the same trouble, changing the MAF sensor has helped us, you can find lots if info here... MAF Sensor A good read for you will also be these two threads.. Fuel Pump O2 sensors as this problem may also have to do with fuel delivery problems. | |
| Subject: Re: Starts and dies, starts and dies. Wed Mar 30, 2011 9:34 pm | |
| The following is just a guess:
you need a set of those LEDs that alarm installers use for diagnosis, basically put one on the hot line to the ICM and the other in parallel to an injector as a NOID. When the car quits DO NOT TOUCH ANYTHING but get out and look at it. If it is still on then your ignition is still on (ICM is hot) and it's probably the crank sensor or some such. If it is off you most likely have an intermittent or faulty ig switch.
hopefully some other folks will chime in on this.
jonly Enthusiast
Name : james Age : 51 Location : Springfield, IL Joined : 2007-04-18 Post Count : 235 Merit : 9
| Subject: Re: Starts and dies, starts and dies. Wed Mar 30, 2011 9:37 pm | |
| - albertj wrote:
- The following is just a guess:
you can rent noid testers at my local parts store. worth asking there. | |
YO MUDA Amateur
| Subject: Re: Starts and dies, starts and dies. Sat Apr 02, 2011 7:41 pm | |
| Had a wrecker tow it to a mech. Hopefully find out Monday. Thanks for the info guys. | |
BMD Aficionado
| Subject: Re: Starts and dies, starts and dies. Sat Apr 02, 2011 7:44 pm | |
| Let us know what the problem is, will 'ya Jimi? | |
YO MUDA Amateur
| Subject: Re: Starts and dies, starts and dies. Sun Apr 03, 2011 9:59 pm | |
YO MUDA Amateur
| Subject: Re: Starts and dies, starts and dies. Tue Apr 05, 2011 7:27 pm | |
| It was just a fuel pump. Guess while im at it I'll clean out the whole system. | |
| Subject: Re: Starts and dies, starts and dies. | |
