DEMonte1997 Aficionado
| Subject: Lukewarm starts take a bit longer... Fri Apr 08, 2011 11:42 pm | |
| If the Riv sits for over 5 hours it starts right up... Same goes for if it sits for less than 1.5 hours. Anything in between and it will most likely take a bit of firing to get going. I'm thinking this could be a few different culprits: -fuel tank leakdown -fuel pressure regulator -injector Seems odd though.... If the tank had an issue, I figure it would start pretty hard the longer it sits.. Anything I might be missing here? I've got a few FPRs laying around that I will try to swap out tomorrow to see if that helps. After that... I ain't touching it. lol
Last edited by DEMonte1997 on Sun Apr 10, 2011 5:19 pm; edited 1 time in total | |
| Subject: Re: Lukewarm starts take a bit longer... Sat Apr 09, 2011 12:39 pm | |
| Leaky injectors? Takes a while to flood the cylinder, then a while longer for it to evaporate... my best guess... | |
