 PCV Valve location
4 posters
GreenSupreme
PCV Valve location Empty
PostSubject: PCV Valve location   PCV Valve location EmptySat Apr 09, 2011 2:28 am
I'm going to replace the PCV valve on my rivi and just want some clarification on it's location, I remember seeing something under the SC snout that looked like it might be it but I'm not certain.
Merit : 149
PostSubject: Re: PCV Valve location   PCV Valve location EmptySat Apr 09, 2011 8:24 am
https://rivperformance.editboard.com/t7272-pcv-valve-location?highlight=pcv+valve
In this picture, the green arrow points to the plate you need to remove.
http://www.paulstravelpictures.com/GM-3800-II-PCV-Valve-Replacement-Guide/Pontiac-Grand-Prix-PCV-Valve-Replacement-003.jpg
http://www.paulstravelpictures.com/GM-3800-II-PCV-Valve-Replacement-Guide/Pontiac-Grand-Prix-PCV-Valve-Replacement-006.JPG
http://www.paulstravelpictures.com/GM-3800-II-PCV-Valve-Replacement-Guide/Pontiac-Grand-Prix-PCV-Valve-Replacement-007.JPG
http://www.paulstravelpictures.com/GM-3800-II-PCV-Valve-Replacement-Guide/Pontiac-Grand-Prix-PCV-Valve-Replacement-008.JPG
GreenSupreme
PostSubject: Re: PCV Valve location   PCV Valve location EmptySat Apr 09, 2011 11:44 am
thanks that really helped, I always figured that was some kinda block off plate which might be used for something on other vehicles
PostSubject: Re: PCV Valve location   PCV Valve location EmptyTue Jun 19, 2012 1:09 am
Is there a gasket for the PCV valve ? I mean for the cover. I took it off and it cracked on me. I was gonna use RTV
PostSubject: Re: PCV Valve location   PCV Valve location EmptyTue Jun 19, 2012 2:08 am
I use rtv .works good.no leaks.
PCV Valve location
» IAC valve location?
» PCV Valve Location
» ecm location
» Removing PCM (Powertrain Control Module)
» FAQ: Where to install the IAT (Intake Air Temperature) sensor...
