| Cars Falling apart literally? | |
trumbo71 Amateur
Name : Tim Joined : 2011-03-25 Post Count : 33 Merit : 0
| Subject: Cars Falling apart literally? Sat Apr 09, 2011 8:40 pm | |
| Pulled in this evening went to leave again and found this part laying behind my car Part Number was barely visible Part # 25643389, says INSULATOR DRIVETRAIN & FRT SUSP FRM LWR, how important is it that I put on a new part should I do it asap? | |
98riv Moderator
| Subject: Re: Cars Falling apart literally? Sat Apr 09, 2011 9:25 pm | |
| _________________ 1998 Supercharged Riviera - Custom CAI, Alpine spx-13ref, Infinity 6x9's, Alpine 4 Channel Amp, Kicker KX3, Silverstars, STB, Hawk Brake Pads, Monroe Air Shocks, KYB GR2
| Subject: Re: Cars Falling apart literally? Sat Apr 09, 2011 9:26 pm | |
| Yeah that's one of the lower insulators for the cradle mounts and it looks like the remnants of the retainer and some other metal. I'd take a look at all 6 mounts but most likely, that's one of the ones at the rear of the cradle. Hopefully that's the only one that looks like that...
If the cradle its-self looks ok, get new insulators and hardware for the ones that are bad from the dealer if you can. Unfortunately, that stuff is diminishing in availability. | |
trumbo71 Amateur
| Subject: Re: Cars Falling apart literally? Sat Apr 09, 2011 9:39 pm | |
| I was thinking the rubber piece is mostly intact except one side, and im sure something was threaded thru it so does this mean the bolts possibly broken.. | |
| Subject: Re: Cars Falling apart literally? Sat Apr 09, 2011 9:49 pm | |
| Take a look underneath - you can almost see it without even lifting the car. If the bolt is still there at all, it's probably half the thickness it's supposed to be now due to corrosion. On my car and every other big body cradle I've looked at, it's always the middle two of the six mounts (the front two on the back side) that are way gone like that. The other four seem to hold up much better. | |
trumbo71 Amateur
| Subject: Re: Cars Falling apart literally? Sat Apr 09, 2011 10:00 pm | |
| Found where it came from, front driver side, its the one facing down the bolts just hanging down with a large circle opening around it i knew it was it as soon as i seen it the passenger side isnt any better looks like its getting ready to pop off aswell...
Can this job be done in a day, or is the hard part finding the parts :/ | |
| Subject: Re: Cars Falling apart literally? | |
