brandonlong Amateur
Name : Brandon Age : 31 Location : Tewksbury, MA Joined : 2011-04-19 Post Count : 39 Merit : 2
| Subject: Various DTCs Series I SC Tue Apr 26, 2011 9:44 pm | |
| Well, I noticed my check engine light wasn't illuminating when I turned on the key, so I ripped out my scanner to check it out and low and behold, it was code frenzy 2! Sucky part is, I just dropped my pan ealier to change my tranny fluid and filter, so those codes can wait a bit. Also does anybody have a pinout diagram for these? If not I'll buy an Alldata subscription. | |
| Subject: Re: Various DTCs Series I SC Tue Apr 26, 2011 11:18 pm | |
| consider clearing all the codes then pay attention to the ones that re-set. | |
DEMonte1997 Aficionado
| Subject: Re: Various DTCs Series I SC Wed Apr 27, 2011 7:11 pm | |
| Sorry I didn't post sooner. Welcome Brandon! Good to see you working through the kinks and doing a decent resto on this car.
I agree with Albert on the codes.... especially the trans 740. After a fluid change on the trans... see if it acts up. It *should* behave better than previous with just new filter and fluid. | |
brandonlong Amateur
| Subject: temp Wed Apr 27, 2011 7:25 pm | |
| Ok cool. I changed the fluid/filter right before I did this, but when I went to clear the codes, they are still there (Engine off, key on). After clearing them I go back in and they are still there, so I am thinking of pullling the negative on the battery, but I am not sure if there is a LOC code on the radio, is there any easy way of seeing before I pull it? | |
| Subject: Re: Various DTCs Series I SC Wed Apr 27, 2011 9:52 pm | |
| if the THEFTLOC light is blinking there is a lock code in the radio.
I think elsewhere on this site is a posting about how to get the code if you don't have it.
brandonlong Amateur
| Subject: Re: Various DTCs Series I SC Wed Apr 27, 2011 10:05 pm | |
| There was not one set, and the DTCs are now all cleared. | |
| Subject: Re: Various DTCs Series I SC | |
