 '95 Motor swap - Transmission Bolts Size
winriv95
'95 Motor swap - Transmission Bolts Size Empty
PostSubject: '95 Motor swap - Transmission Bolts Size   '95 Motor swap - Transmission Bolts Size EmptySat May 14, 2011 10:14 pm
Im trying to swap my motor on my 95 rivi tomorrow.. Can sonebody please tell me what size the bolts are to release transmisson nerd help asap my only day off for next to weeks
PostSubject: Re: '95 Motor swap - Transmission Bolts Size   '95 Motor swap - Transmission Bolts Size EmptySat May 14, 2011 11:02 pm
18mm
winriv95
PostSubject: Re: '95 Motor swap - Transmission Bolts Size   '95 Motor swap - Transmission Bolts Size EmptySun May 15, 2011 8:38 am
Ty thats what I thought someome said it was smaller glad I bought 18mm he was talking like 5/8th
winriv95
PostSubject: Re: '95 Motor swap - Transmission Bolts Size   '95 Motor swap - Transmission Bolts Size EmptySun May 15, 2011 3:57 pm
I removed 4 bolts from tranny but engine will not move at all is there a bolt or something else im missing? Released exhaust and all wire harness .... Wtf this 4t60e is pissing me off wish I could upgrade it . Someone please help
PostSubject: Re: '95 Motor swap - Transmission Bolts Size   '95 Motor swap - Transmission Bolts Size EmptySun May 15, 2011 8:51 pm
There are 5 bolts holding the tranny to the engine. One is down on the rear side between the transaxle and the engine block. You need a long extension and possibly a universal to get it out. Removing part of the bracket under the power steering pump will give you a little more access. There are 3 bolts on the bracket. 2 are on the horizontal surface.You will need a 13mm box wrench for the one, as there is not enough room to get a ratchet on it. I hope this helps.
winriv95
PostSubject: Re: '95 Motor swap - Transmission Bolts Size   '95 Motor swap - Transmission Bolts Size EmptySun May 15, 2011 11:59 pm
Is the bolt on passenger side or driver side?
PostSubject: Re: '95 Motor swap - Transmission Bolts Size   '95 Motor swap - Transmission Bolts Size EmptyMon May 16, 2011 7:47 am
The bolt is more toward the drivers side. Through the bell of the tranny. Just like the 4 you already took out. From under the car you have to go at it from the passenger side with a long extension and an 18mm socket. It is just below the rear exhaust manifold.
» Easy Belt Length Calculation: Pulley Swap Only
» tranny question
» exhaust tip bolt size...
» pulley swap on a hydro
» Murray Rear Engine Tractor
